Old 05-06-2008
puff6022 is on a distinguished road
Rust on Dacron Sails
How do you get rust stains out of Dacron 6 oz Sails
Old 05-06-2008
johnr
jr438234606 is on a distinguished road
how about Vinegar, or StarBrite Rust Stain remover?
Old 05-06-2008
Catalina274me's Avatar
Catalina274me is on a distinguished road
Rust Stains
I read somewhere that rubbing a lime works. The newer the stain the better it works. Sometimes all the stain is not removed but the sunlight will finish "bleaching" it out.
Catalina 27
Columbia River, Wa
Old 05-06-2008
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
A very light solution of oxalic acid should remove the stain; but use it only at the stain not on the entire sail. It's possible that lime juice is strong enough with citric acid; so you could try that first.
Old 05-06-2008
White vinegar might work too, and it is a pretty mild acid. Cheap too.
Old 05-06-2008
beej67's Avatar
beej67 is on a distinguished road
Toilet bowl cleaner does wonders for rust on fiberglass, but it eats holes in metal, so I'm not sure I'd use it on dacron.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
Old 05-06-2008
Merkimber is on a distinguished road
Rust Stains
Greetings, I found that oxyclean powder mixed with lemon joy soap & water works extremely well.Scrub sail with solution then let the sail bask in the sun for awhile before rinsing. Oxyclean does not have bleach and does not appear hurt the thread or breakdown the fabric. Good Luck! It worked great for me! Merkimber
Old 05-06-2008
RickQuann's Avatar
RickQuann is on a distinguished road
I've used limes, which are okay on a "fresh" stain, but if I ever need to remove a stain again, I think I may try the white vinegar method instead.
ON & OFF is the best hull cleaner I've ever used. Be sure to have plenty of ventilation and wear protective gear because the fumes are real unpleasant.
Sail Repairs at Sea Brian Hancock Gear and Maintenance Articles 0 09-22-2003 08:00 PM
Rust Never Sleeps John Kretschmer Gear and Maintenance Articles 0 02-27-2003 07:00 PM
