Blogs
User Name
  #11 (permalink)
Old 05-09-2008
camaraderie's Avatar
camaraderie camaraderie is online now
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
I am thinking loss of coolant...slow leak somewhere.
Tayana 52 Ketch
  #12 (permalink)
Old 05-09-2008
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
"The fact that it shuts off when you turn your thermostat up to 5 rules out a relay in my opinion, after all, it did shut off."
Good point!
That does sound more like "I just can't keep up" which could be slight refrigerant loss, etc. One quick way to test for that would be to load in some block ice or dry ice to provide extra cooling, and then try again with the thermostat set down cold. If it cycles and works properly that way--then the gas loss would be very likely. Or, more/new insulation, but either way you'd need to check the gas charge or check for leakage. The simplest way to test for gas leakage is to spray all the fittings with bubble-soap, and then look to see if anything is blowing bubbles. That would only show a fairly large leak though. A "sniffer", for less than $100 used from eBay or a pawn shop, is way more sensitive (will pick up leaks that are less than 1 oz. of refrigerant per year) but costs a bit more up front, and requires some patience to work with. An essential tool for DIY refrigeration/AC maintenance though.
  #13 (permalink)
Old 05-12-2008
recycle recycle is offline
recycle is on a distinguished road
refer
When I bought the boat last July I had the coolant gas checked and they did add a little to it. He also checked for leaks and found none. It does go below 38 and will keep going. It gets very cold in there and everyone keeps stopping by because I guess I have the coldest beer. It will shut off when I turn the knob past 0 and I feel a click. I think this is the off position.
I'm going to take a look at the relay if I can find it and possibly the thermostat.
I'm in slip right now but will be on my mooring soon so the power drain will become an issue.
Thanks for all the help. This is our first boat with referigeration.
Tartan 3800
Luna
East Greenwich RI
  #14 (permalink)
Old 05-12-2008
FWIW: "He also checked for leaks and found none. " That doesn't mean there are no leaks, they can be difficult to find, even when the tech is doing things properly. Leaks are something like poker: The game is deceptively simple.
  #15 (permalink)
Old 05-12-2008
JiffyLube's Avatar
JiffyLube JiffyLube is offline
Grasshopper
JiffyLube is on a distinguished road
Originally Posted by hellosailor View Post
When cars "all" had ignition points and replacing them was a part of every tuneup (and they cost something like 10 gallons of gas? 20?) it was routine to polish the points that way, to prevent them from sticking.
And to get more mileage out of the points before you had to buy new ones...I know because I still have a truck that has points...lol
  #16 (permalink)
Old 05-12-2008
JiffyLube's Avatar
Grasshopper
I second the idea of checking out Kohlman's website KollmannMarine Boat Refrigeration Specialist . I think I read about your problem in their forum, while I was trying to solve my situation.
  #17 (permalink)
Old 05-12-2008
ehmanta's Avatar
ehmanta ehmanta is offline
Sailing Junkie
ehmanta is on a distinguished road
Could also possibly be over-charged if the lines are freezing up.
This passage is from Frigoboat:
"Too much refrigerant in the system will result in liquid still evaporating back to a gas past the end of the evaporator and inside the tubing going back to the compressor. This means that there is still some of the refrigeration process going on inside the tubing and there will be a build-up of frost or ice on the exposed section. If additional insulation has been added, it may be concealing this symptom and should be removed. The evaporator may appear and sound normal, but will be at a higher temperature than desired, resulting in longer than expected run times."
These links could help:
RParts: Refrigeration Parts Solution
Design Your System
  #18 (permalink)
Old 05-13-2008
Thanks
Thanks for all the help. I'll do some more investigation this weekend. Should be fun. At least it works and keeps everything cold.
Tartan 3800
Luna
  #19 (permalink)
Old 05-13-2008
chucklesR's Avatar
chucklesR chucklesR is offline
Gemini 105Mc Hull 987
chucklesR has a spectacular aura aboutchucklesR has a spectacular aura aboutchucklesR has a spectacular aura about
Cool, literally. Think propane. It's cheaper per 'erg' than any other system.
  #20 (permalink)
Old 05-13-2008
erps's Avatar
erps erps is offline
Puddin' head
erps will become famous soon enough
Why do you suppose they're not more widely used on boats?
Display Modes
vB code is On
Adler-Barbour Refrigeration one blinking light SanDiegoChip Gear & Maintenance 11 06-13-2007 08:51 PM
Refrigeration Conservation Cruisingdad Cruising 41 04-26-2007 06:57 AM
Installing 12-Volt Refrigeration Sue & Larry Gear and Maintenance Articles 0 06-18-2002 08:00 PM
Installing Refrigeration Sue & Larry Gear and Maintenance Articles 0 05-08-2002 08:00 PM
Refrigeration Systems SailNet Miscellaneous 0 08-27-2000 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
