The
fuel gauge on my boat won't read above 1/4 full. It was working OK last season, but now when I turn the key it won't rise above that level no matter how much gas is in the tank. I'm not even sure it would read less than that level, either. A friend told me that if the gas was "varnished" at all it would coat the sensor so that it wouldn't send properly.
Is this problem more likely the gauge or the float sensor? If it is the sensor, are those things generic for gas tanks or do you have to get one that specifically fits the tank? Obviously the gauge would be no problem to replace.
Thanks!
