Anyone seen these spots before?? - SailNet Community
Blogs
Old 05-07-2008
cas8100 is on a distinguished road
Hi all... This thread is a continuation of the previous thread Paint build-up or Barrier Coat? I've finished sanding all of the old paint off the bottom of my Catalina 22' and have 50 or so possible problem spots. This is my first project of this type and I was hoping someone out there might be able to identify these spots.
I've attached 3 pictures, the first is of what I think might be some type of fiberglass rot or pre-blister area. The second picture I'm not quite sure if its an old epoxy fix or maybe the beginning stages of picture 1. Picture 3 is a combination of the two.
I'm wondering if anyone has ever seen similar looking spots and if anyone has advice as to how to handle them. My plan was to grind into the glass and patch with Interlux Water-tite Epoxy Filler.
Thanks all.
Old 05-07-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
1 = blister, through the gell and into the glass.
2 = beginning blister
3 = previously patched (spot repair) blister.
There have been many posts already on blister repairs, the advice given in those posts has the full realm of info on how to repair them.
Old 05-07-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
#1. is more likely where air gets trapped in the glass. Unless when you sanded it down a noticeable water came out.
#2 and #3 its possible that there just was enough epoxy to hold the gel coat?
Either or nothing to major to worry about - use the filler - epoxy, prime and paint over...Just make sure you follow the instructions to the T and keep the areas cleaned before and after each process.
-- Jody
S/V "
1983, Barberis Show 38! or
Old 05-07-2008
#3 may have also been a layup void instead of a blister.
Old 05-07-2008
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
#3 looks like a repaired blister; the "pink" stuff in the middle might be polyester fairing compound (AKA Bondo). If you allowed the hull to dry out before sanding it the others may be blisters that have flattened out a bit. Poke and/or tap with something hard to see if the hull flexes beneath and if so then you will have to grind back the area and re-fair with a fairing compound.
Brunch spots on SF Bay ysabelsdad General Discussion (sailing related) 8 03-02-2008 08:29 PM
Stainless Surface Rust Spots HatterasJack Gear & Maintenance 8 08-29-2007 12:15 AM
Crazying and Soft Spots on Deck GarrettK Gear & Maintenance 4 08-23-2004 01:57 PM
Dodger window spots mrb2222 Gear & Maintenance 3 08-03-2004 04:25 PM
Tiny rust spots from nearby grinders VIEXILE Gear & Maintenance 7 04-09-2004 06:22 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
