Blogs
User Name
  #41 (permalink)
Old 05-22-2008
tommyt tommyt is offline
tommyt is on a distinguished road
OK, I ordered the Natural Cetol and Gloss after reading this thread through a couple of weeks ago. Then I see that Gloss can lift!
So, I am just doing companionway boards. They were originally done with Cetol light, NO gloss. They lasted 4 years and I was happy with the product. I have started the Cetol project with a first coat to one side, and am looking at a six day project to get three coats of Cetol on. I like the color so far.
Question? Other than the gloss look, what do I gain with the gloss? These three boards are in a pocket when not in use. They do rub together, but the old Cetol finish looked just fine for the four years. I am not a varnish snob obviously, so please give me a reason not to take the gloss back to the store if there is one.
  #42 (permalink)
Old 05-22-2008
TrueBlue's Avatar
TrueBlue TrueBlue is offline
Seņor Member
TrueBlue is a jewel in the roughTrueBlue is a jewel in the roughTrueBlue is a jewel in the rough
tommy,
In my experience using Cetol Light for three full years - and a Cetol Clear (gloss) for an overlap of two seasons - total of 2 clearcoats, never did I see any signs of it lifting.
The Clear serves two purposes; being a bit harder than the minimum base of 3 coats of the heavy body, semi-translucent Cetol, it provides a protective clearcoat and prevents a gradual build-up of solid body paint. At least one maintenance coat is necessary each year - so after a few years regular Cetol will become less translucent and more opaque.
The Clear however, is softer than varnish, so if it ever gets scuffed - retouch the scared area immediately, first with Natural (Light, or Original), then another coat of Clear. Otherwise the teak will blacken.
True Blue . . .
sold the Nauticat
  #43 (permalink)
Old 05-22-2008
camaraderie's Avatar
camaraderie camaraderie is offline
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Ditto that...no lifting in YEARS of full time cruising. Go with the gloss.
Tayana 52 Ketch
  #44 (permalink)
Old 06-05-2008
KeelHaulin's Avatar
KeelHaulin KeelHaulin is offline
STARBOARD!!
KeelHaulin will become famous soon enough
The finish can start to lift at edges where water can get beneath the finish; so if you can paint the backside of the wood with a sealing coat or two to prevent water from getting beneath the finish. If it does start to lift you can sand it back and then put some touch up of the base coat; followed by clear. I don't think the lifting is specific to the clear coat; it's just the same as any other finish when it comes to delamination due to water working in.
I am switching over to the Natural Teak. My coaming, hatches, handrails, traveler are done with Light and will stay that way until I decide I want to go through the hard work of sanding them down and re-finishing them. For now they look great (well until the newly finished hatch boards and locker doors go in).
I'm wondering what can be done to prevent the finish from pulling away from the dark grain? Seems that even if wiped down with acetone the finish will not sit flat on the surface after it dries a bit. Any info on how to get the cetol to remain smooth?
  #45 (permalink)
Old 07-05-2008
ericroline's Avatar
ericroline ericroline is offline
Cal 9.2 Silver Swan
ericroline is on a distinguished road
The old Cetol utilizes iron oxide as a primary additive for enhanced UV protection. The other less opaque versions are good, but the original has the longest lasting protection. A mater of choice, bright work or the colour? What do you dislike the most?
Display Modes
vB code is On
Is there life after Cetol Quickstep192 Gear & Maintenance 15 10-27-2007 12:08 PM
Messy Cetol on NonSkid lmitchell Gear & Maintenance 3 02-13-2007 04:14 PM
Haze on new cetol ??? skyamsen Gear & Maintenance 2 10-20-2003 06:53 PM
Cetol...off! cgha33 Gear & Maintenance 10 09-18-2003 09:09 AM
Cetol vs cetol light Lastmango69 Gear & Maintenance 2 07-22-2003 04:12 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
