Heat Exchanger help - Page 2 - SailNet Community
post #11 of 15 Old 05-08-2008
artbyjody's Avatar
Have you checked the water strainer? I had the same identical situation, and it ended up being that the water strainer was clogged with algae... (Thanks again David)... it could actually be that simple.
Most water strainer at least for diesels - are very small and under sized resulting the symptoms occurring more heavily. The reason why it is not happening at the dock is that you are not putting any load on the engine and therefore it draws less water...When motoring it draws more and the water strainer when clogged will more readily restrict the flow that is required.... so it may not be the heat exchanger after-all....(I am assuming this was something not looked at)....
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #12 of 15 Old 05-08-2008
beej67's Avatar
Also (maybe this needs to be another post) there is no raw water screen between the thru hull and raw water impeller. Shouldn't there be one to catch debris coming in? Thanks for all the help!
Yes, there definitely should be. Mine's in the bilge, near the thru hull valve.
Here's a good photo I just yoinked from Google Images, but I'm guessing it's from a power boat. (look at all that space!)
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
beej67 is offline
post #13 of 15 Old 05-08-2008
T37Chef's Avatar
All the previous suggestions sound right on. Last year I was having hot engine issues, did everything suggested, plus flushed the fresh water cooling system, replaced thermostat, impeller, & several hoses. Then ran a product called Barnacle Buster Concentrate from Trac Ecological through the system. I let it sit overnight and flushed it out, no more worries. I plan to do this probably every other year now.
TRAC Ecological Marine Products
Shawn
T37Chef is offline
post #14 of 15 Old 05-08-2008
Freesail99's Avatar
This is the link I was looking for. Great stuff, worked well for me.
S/V Scheherazade
Freesail99 is offline
post #15 of 15 Old 05-20-2008
Perhaps you have a problem with the shaft alignment? Even if you ran the engine at the dock on forward I don't think you did it in full power did you? In which case it would overheat only on water when in cruise speeds...
sendrom is offline
heat exchanger and motor paint jasonr575 Morgan 8 03-09-2013 08:06 PM
Heat exchanger cap partial failure Valiente Gear & Maintenance 9 06-01-2007 12:09 AM
Transmission Heat Exchanger gconley Gear & Maintenance 7 11-05-2006 09:45 PM
Heat Emergencies William Mahaffy Seamanship Articles 0 12-18-1998 07:00 PM
Heat Emergencies William Mahaffy Her Sailnet Articles 0 12-18-1998 07:00 PM
