Saw this at the boat yard !!!! - Page 3 - SailNet Community
post #21 of 24 Old 05-09-2008
seeker
Gary;
With Imron and most other LPU paints the object in buffing is not to abrade it with a grit. no matter how fine, it is to buff it with a higher speed buffer using a product like 3M final buff or any of the myriad of products by 3m or Norton or McGuire's specifically for this application. They are not an abrasive but more like tiny balls that roll around with the pad and essentially soften the finish with heat and cause the surface to flow. I attended the DuPont finishing school a few years back and they demonstrated the procedure by taking various panels of various ages from 24 hours to several years and intentionally damaged them with 120 grit paper then polished them out. The effect was like magic to someone used to acrylic lacquers and enamels that do not soften with friction. The older panels took more time but flowed out all the same. Talk to an auto body supply store regarding the system to use and spend the $ on a good powerful buffer and you can amaze all your friends and have a fabulous party trick.
Feetup
feetup is offline
post #22 of 24 Old 05-09-2008 Thread Starter
Maine Sail's Avatar
The red boat..
The red Imron boat was actually done with 3M rubbing compound BUT I did NOT use a compound grade pad. I used a polishing grade foam pad and it was buffed wet and at speeds no greater than 1500 rpm. I followed up the 3M product with Presta Chroma 1500 polish and a Presta specific pad for Chroma 1500. I would have used Presta Ultra Cutting Creme as my starting point but I was out..
Imron will buff out like a traditional paint but do be very careful. If you're an amateur DO NOT use a rubbing compound on Imron, ,as I did, or you'll get in trouble...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #23 of 24 Old 05-10-2008
garymcg's Avatar
Great, thanks for the pointers. Much appreciated.
garymcg is offline
post #24 of 24 Old 05-10-2008
Junior Birdman
Originally Posted by MedSailor View Post
Does anyone else see a tallship on the right hand side being chased by a dreadnaught battleship on the left side of the picture?
Disclaimer: I haven't had much sleep lately....
MedSailor
My kid thought it looked like spongebob.... I just thought... WOW what a shame, nice looking paint!
1988 Seaward Fox
no name yet (it's in pieces!)
Coconut Grove, Florida
Iflyka200s is offline
What's your biggest bonehead move sailing? CharlieCobra Seamanship & Navigation 613 07-19-2016 08:10 PM
Modern Hull forms and Motion Comfort Jeff_H Sailboat Design and Construction 193 10-31-2013 09:29 AM
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
Two-Boat Tuning Dean Brenner Racing Articles 0 03-13-2002 07:00 PM
The Balance of Hull and Sails Steve Colgate Seamanship Articles 0 05-25-2000 08:00 PM
