05-10-2008
I would cut off the plug, leaving about two-to-three feet of cable. Strip about a foot of the cover from both pieces and then use heat shrink crimp connectors to re-splice the wires, staggering the splices, and then cover the with a single piece of adhesive lined heat shrink tubing.
Staggering the splices will make the cable far less bulky. The outer heat shrink covering will help protect the splices from damage, like the outer jacket would do for the wires in the rest of the cable.
I don't recommend soldering wires on a boat. Use a good crimper—like an Ancor ratcheting crimper and a high-quality adhesive lined heat shrink tubing and crimp fittings.
