Those little green Coleman propane bottles - Page 4 - SailNet Community
post #31 of 39 Old 05-22-2008
True value hardware stores often have the 5 lb. propane tanks in stock. You can also buy them on-line.
sailingdog is offline
post #32 of 39 Old 05-22-2008
I have seen them at canadian tire. Superior Propane may or may not have it in stock but they can order them.
bushrat is offline
post #33 of 39 Old 05-22-2008
By the way these smaller sized refillable cylinders can safely be refilled useing the proper fittings and a hose from say a regular 20lb one. This makes your propane purchases very economical. Some places have a flat rate per pound but you are often paying more per lb to fill a smaller cylinder.
bushrat is offline
post #34 of 39 Old 05-22-2008
When I was younger and dumber I had the little greenies inside the storage area in my little Oday 20(which wasn't sealed off from the cabin) until my dad went sailing with me and saw the little greenies where the shouldn't have been. He pointed out on the label where it said not to store them inside and that they are not to be refilled. I then got to go swiming against my will for being a dumb dumb gum gum. Good thing the water wasn't freezing cause it was a long swim back to the dock.
Islander30Bahama is offline
post #35 of 39 Old 05-22-2008
Better a long cold swim back to the dock than you turn yourself into boat confetti later... I bet you haven't forgotten that lesson, and won't make that mistake again.
post #36 of 39 Old 05-22-2008
Damn skippy SD That is one lesson that will never be forgotten. On the new boat I plan on building an aluminum airtight container here at work to store the large 20lb bottle that I will use for the galley as well as the bbq. Probably install propane detectors inside it and in the bilge as well. I recently saw a boat on craigslist that had a propane explosion in it was not a pretty sight.
post #37 of 39 Old 05-22-2008
Shouldn't be air tight...should have a drain overboard for the any propane gas that leaks to drain out. If it is airtight, it could be come an explosion hazard.
post #38 of 39 Old 05-22-2008
So one small vent line to the top of the container ran up mounted on the outer side of the (gunwhale? the raised part of the cockpit where the sheet winches are?) then one out of the bottom to the stern to keep air circulating through to prevent any build up of explosive gases? Then place one propane sniffing sensor in the bottom of the cockpit storage then one in the bilge in the salon somewhere to be totally safe? I want it to be totally safe cause its my baby and will be my home this fall.
Thanks SD
post #39 of 39 Old 05-22-2008
Just remember the drain for the propane should be as low as possible in the locker, since propane is heavier than air, and should not have any bends in the drain line that might trap water and prevent the drain line from functioning properly.
Propane Cabin Heater Mysun Gear & Maintenance 9 06-07-2009 11:29 PM
Wondering about where to put propane sensors... Sailormann Gear & Maintenance 5 05-14-2007 11:58 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 08:00 PM
The Green Flash Dan Dickison Cruising Articles 0 02-28-2002 07:00 PM
From Propane to Butane John Kretschmer Gear and Maintenance Articles 0 09-23-1999 08:00 PM
