Old 05-10-2008
maiden is on a distinguished road
Auto pilot ST6000
I am having trouble with the auto pilot. The mechanics seem to work okay, but I can't get the boat to go to anything other heading other than 063 degrees - how do I know if I need to replace the fluxgate compass or the control head?
Old 05-10-2008
Has the autopilot ever worked previously?
Have you checked the area around the fluxgate compass for interference?
Have you re-calibrated the fluxgate compass?
Old 05-11-2008
Zanshin's Avatar
Zanshin is on a distinguished road
Does the compass show other courses on your display when you are on other headings? If no, then your fluxgate compass is at the source of your problems. You might try to switch your ST6000 to use wind direction instead of compass course (I can't remember the key combination now, but it was just a couple of keystrokes) and see if it steers correctly via wind angle. If no, then problably your compass isn't faulty but your main unit it.
Old 05-11-2008
SYMandalay is on a distinguished road
Raymarine has a pretty good help line.....call one of their reps and he should walk you through some steps to isolate the problem.
Old 05-11-2008
tommyt is on a distinguished road
Raymarine will also do diagnostics on your unit and let you know if it is your problem. At a minimum they update it before sending it back to you. The 6000 is a good autopilot. Hope you find your issue soon.
Tiller auto pilot wildlone Gear & Maintenance 10 03-08-2011 12:44 AM
ST6001 vs. ST4000 auto pilot ddilman Boat Review and Purchase Forum 5 01-05-2005 09:01 AM
ST6001 vs. ST4000 auto pilot ddilman Gear & Maintenance 1 01-03-2005 02:53 PM
Fine-Tuning the Autopilot—Part One Dan Neri Cruising Articles 0 09-03-2003 08:00 PM
New Auto pilot Raymarine vs simarad obiec Gear & Maintenance 7 01-14-2003 02:08 AM
