Old 05-11-2008
papasailor is on a distinguished road
Vicious cycle
After 4 yrs on hard, I am cleaning my boat to go back in the water. It's an 85 Catalina 30 TRBS. Eight yrs ago, I did a 1000/1200 sandpaper job followed by buffing, polishing and waxing. My arms about fell off but it looked great.
The hull still looks good after 4 yrs of dirty rain and sitting. The problem eight yrs ago is the same as it is now. Although covered, the topside is filthy. I used an electric power washer to remove of a layer dirt but like before, I had to use Softscrub W/bleach and scrub to get it really clean.
No doubt, the fiberglass has microscopic pores allowing dirt to penetrate. This includes bird poo, especially after birds visit nearby blueberry fields. I realize bleach and hard scrubbing deteriorates the fiberglass and lets dirt go deeper but it's the only way to get it white. I'd love to polish the deck, even use fine sandpaper or a buffer, like I did on the hull. However, most of the deck is non skid. It's not the gritty non skid, but rather the molded pyramids like the bottom of a bathtub.
The question is how to stop the cycle of cleaning with bleach which makes dirt go deaper, requireing more bleach, etc, etc.
I bought some stuff called "Nu Glass" a few years ago but have not used it. Today, I bought a bottle of StarBrite Non skid cleaner which has something called "PTF" that is supposed to seal the fiberglass. If it ever stops raining, I will check it out but won't know for sure until it gets dirty and sits in the sun for a while between going out. Depending on how it works or any feedback here, I may apply the Nu Glass.
If anyone has a thoughts on how to get past this vicious cycle, please let me know.
Old 05-11-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
I am doing my the non skid area of my top sides with a product called kiwigrip.
Anti-skid Boat Decks from Pachena LLC - KiwiGrip anti-slip deck coating
I will epoxy the area first and then scuff it up and apply the kiwi grip. If you think about it, that is a major part of the deck area of your boat.
Good luck.
S/V Scheherazade
Old 05-11-2008
Don't use NuGlass.. It has a really horrible reputation for yellowing and generally looking like crap after a while. I"ve used the StarBrite Non-skid cleaner with PTFE, and it is pretty good stuff. The non-skid is usually stickier than before cleaning with that stuff. How they make non-skid stickier with something that has TEFLON in it is beyond me...
If you really want to reseal the topsides, use PoliGlow. However, DO NOT USE POLIGLOW on the NON-SKID, unless you want to end up in the water. It will turn your non-skid into ice-like material.
Freesail—
You probably want to sand the non-skid areas before epoxying them, to give the epoxy the best bonding surface to attach to.
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 11:19 AM
O/B motors 2 stroke vs. 4 cycle catalyst27 Gear & Maintenance 22 09-11-2006 09:38 AM
At sea. Volvo Ocean Race: ABN AMRO TWO in a vicious circle @ BYM Sailing News NewsReader News Feeds 0 04-10-2006 03:16 PM
Reverse Cycle Heat AC Stormer Gear & Maintenance 4 11-16-2003 11:05 PM
Are All Deep Cycle Batteries Alike? chuck711 Gear & Maintenance 14 07-02-2003 07:10 AM
