Fresh Water System - Page 2 - SailNet Community
post #11 of 12 Old 05-13-2008
'72 Pearson 36
SVDistantStar's Avatar
Send a message via AIM to SVDistantStar
Well theres only 2 sinks in the boat. I think i may stick with the foot pumps. No power draw.
1972 Pearson 36 S.V. Distant Star
SVDistantStar is offline
post #12 of 12 Old 05-13-2008
JimsCAL's Avatar
It's unusual today for a boat your size not to have hot-and-cold pressure water. I don't think you will find a propane hot water heater that can be permanently installed in you boat's system. Since your boat is on a mooring, the lack of power draw by using foot pumps is an advantage.
The advantage of an accumulator is that is reduces the pump cycling. Without an accumulator, the pump will start and stop every time a faucet is open or closed. The accumulator stores a small volume of water under air pressure. The air can thus expand and the pump will only start when the accumulator pressure has dropped to the switch cut-in point. It's the constant on-off cycling that will kill a pump early.
JimsCAL is offline
water in engine oil?!?!? msbam207 Gear & Maintenance 20 08-22-2007 02:45 AM
convert from sea water to fresh water cooling.... john232 Gear & Maintenance 3 02-16-2004 03:44 PM
Flushing the fresh water system tjr3c General Discussion (sailing related) 0 04-25-2003 06:45 PM
