Blogs
User Name
Old 05-12-2008
papasailor papasailor is offline
papasailor is on a distinguished road
more advice please - teak
Each day brings another question. My teak was varnished (yeah, I know, mistake) but now it is all sanded, washed and ready for finishing. Years ago before the devel made me varnish, I used Sikkens Cetol. I am thinking of using that again but I have choices. The transluscent clear seems to be the best buy because it is available in a gallon. For the same price, I'd get about 2-1/2 qts but that is the way it is with all paints. Gallons are more economical.
Another choice is the Sikkens "natural teak" which looks like it would be darker. Of course, it only comes in quarts.
Is there a recommendation? What about Teak so le'? or other product? My boat will be used for both racing and evening cruising.
On the subject of teak, I really hate finishing it off the boat, mount, plug holes, cut flush, sand and refinished over the plugs. For some items, which mount through with nuts on the inside, I epoxied through bolts in the wood. The long hatch slider boards have to be screwed to the topside so isn't an option. Either I do the plug thing or I plug first, finish and use a flat head screw countersinked in the wood with a dab of sealant under the screw head. It won't look as nice but it will eliminate the extra step of sanding and finishing on board. Any thoughts?
Old 05-12-2008
lbdavis's Avatar
lbdavis lbdavis is offline
Coastal Cruiser
lbdavis is on a distinguished road
Papa,
Concerning Sikkens "natural teak", read here.
Old 05-12-2008
ronbo1 ronbo1 is offline
ronbo1 is on a distinguished road
Cetol's Gloss isn't designed to be applied to bare wood. It's meant to be an overcoat only. Reason being: it's clear and having no UV inhibitors it will peel in a short time.
Try the new Cetol Natural Teak, it appears more natural looking than Cetol Marine and with an annual coat of Cetol Gloss will approach varnish's look.
Ronbo
Old 05-12-2008
camaraderie's Avatar
camaraderie camaraderie is online now
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Sorry...but Cetol GLOSS does have extensive UV protection and is designed to last for 1 year before a new application is needed. It does not peel if properly applied and simply wears like the other Cetol products which provide even more UV protection. Full specs here:
http://www.yachtpaint.com/Images/15_21133.pdf
Tayana 52 Ketch
Old 05-12-2008
T37Chef's Avatar
T37Chef T37Chef is offline
Boat Show Sucker
T37Chef will become famous soon enough
To clarify...Cetol Gloss should not be used alone, but as a topcoat to either Cetol Original (yuck), Cetol Light, or Cetol Natural.
Ignore Power: I'm ignoring them
To get the most from Sailnet, follow the link in TheFrog's signature
Display Modes
vB code is On
Advice refinishing teak and holly sole mcagney Gear & Maintenance 10 02-20-2006 08:16 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 08:00 PM
Advice Bedding Teak sjacovino Gear & Maintenance 2 05-17-2002 06:02 AM
Bristol Teak Tom Wood Gear and Maintenance Articles 0 11-02-1999 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
