Blogs
User Name
  #11 (permalink)
Old 05-13-2008
hertfordnc hertfordnc is offline
hertfordnc is on a distinguished road
So EO32, Tell me about your workout program? I'm in reasonably good shape for my age and I did all those things but when that compression lever is closed that motor STOPS spinning.
On a good battery it starts very easy and it runs great.
I wonder if there aren't different flywheels on some engines?
I've hand started other diesels this way but this one does not seem to build much inertia.
Thanks
In over my head?
First Boat, a well-equipped 1977 Camper Nicholson 31
What is all this stuff and how does it work?
  #12 (permalink)
Old 05-13-2008
chucklesR's Avatar
chucklesR chucklesR is offline
Gemini 105Mc Hull 987
chucklesR has a spectacular aura aboutchucklesR has a spectacular aura aboutchucklesR has a spectacular aura about
Chuckles-
That's because you keep forgetting to put the saildrive leg down.
Yanmar on my old Hunter SD, Westerbeke and saildrive on the Gemini.
For what it's worth folks, on my Gemini I have a drive leg that drops down off the stern. I can see the prop in the water while sailing. Just from looking, it does not spin fast enough in neutral to start. Sailing fast (10knts) then dropping the leg wouldn't work as the leg would (has) literally bounced along on top of the water.
I'd like to hear from anyone who has 'sail' spun his motor to a successful start.
  #13 (permalink)
Old 05-13-2008
Zanshin's Avatar
Zanshin Zanshin is offline
Zanshin is on a distinguished road
The only human hand that can start this engine is that of Maradonna and most Americans won't understand why.
Zanshin - 残心
  #14 (permalink)
Old 05-13-2008
denby's Avatar
denby denby is offline
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the roughdenby is a jewel in the roughdenby is a jewel in the rough
Originally Posted by hellosailor View Post
From what I've experienced, you need three men, two of them big strong grinders and the third nimble enough to reach and engage the compression lever without getting in the way of the two guys grinding. Then, with some luck AND a can of starting ether, you may be able to fire it up.
A can of starting ether is an extremely valuable part of this--the diesel needs some help at times like this. If you don't have ether...WD-40, butane, whatever you've got, try!
I would not use ether on a diesel, WD-40 or engine fogger used to winterize the engine. Ether is not good for a diesel engine.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
  #15 (permalink)
Old 05-13-2008
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
"Ether is not good for a diesel engine." No, it isn't good for routine use.
But when your options are staying out for an extra week, hitting a lee shore, or trying to finance a tow boat, sometimes "not good" becomes a different pecking order. Everything is relative.
A diesel engine itself is "no good" unless it can be started. Worse, it is smelly and heavy, too.
  #16 (permalink)
Old 05-13-2008
EO32's Avatar
EO32 EO32 is offline
EO32 is on a distinguished road
I'm 51, a little overweight, 225 lbs, 6 foot.
When I get the urge to workout, I tend to sleep until it passes.
I think the trick is how much fuel. I find that it will not start on full throttle, but 1/2 throttle.
It is a workout to get it started. It takes about 6 turns to get it up to speed, then drop the decompression while cranking and get the first compression to fire. I usually takes two or three tries.
  #17 (permalink)
Old 05-13-2008
bubb2 bubb2 is online now
bubb2 will become famous soon enoughbubb2 will become famous soon enough
I am still unsure how this is done, as when I bought my boat new with a 2gm20f it didn't come with a crank handle and a winch handle does not work! What do you guys crank with or where did you get the handle?
  #18 (permalink)
Old 05-13-2008
MedSailor's Avatar
MedSailor MedSailor is offline
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
Originally Posted by Plumper View Post
First, I have not been able to start my 2QM20 by hand yet. My friend, who has one, can. He says that the trick is for one person to grind as fast as he can and for a second person to flip the decomp lever on one cylinder without telling the grinder when. The grinder still keeps grinding for all that he's worth.
I had a 2qm20 on my last boat and due to some starter issues (probably my wiring) right before I sold her I pretty much ONLY started her by hand. I'm 5'10" average build. I must admit the first many times I tried it I thought it was impossible but it is definitely do-able. The quote from above is pretty much the meat of it. It really takes 2 people. One cranking like MAD and the other releaseing the levers. I told them when and tried to time it when I was on the part of the stroke where I was pulling towards myself. Doing it by suprise might work also.
I found several technique tweaks before I could reliably start it. First, stack the deck in your favor. Start the engine during the warmest part of the day if possible. Putting towels on the engine and pouring hot/boiling water on them and leaving them for a while helps to heat the engine. You can also crank with levers decompressed while someone holds a blowtorch near the air intake to warm up the calendars. You can also use the torch to heat up the air intake manifold before cranking so that the air passing by it warms.
Remember that on the 2qm20 the handle will not kick back at you so you don't need to hold it in a weird way and be scared of when it starts. It freewheels just like when you stop pedaling a bike. Grasp the handle and get serious! Speed is the key. I would use my entire upper body, not just my arms.
I found that a good stance was really important. I would take out a bilge floorboard and brace my legs between stringers for a solid stance.
WD40 definitely helps and is great for your engine (most of these tricks I got from a cruise ship mechanic that helped me start my engine after I got the starter submerged in salt water ) Don't just do a little squirt either, have the person holding the levers in one hand, wd40 in the other, he waits until you have a few turns, begins spraying and 3-5 more revs later when you've got some speed on he lets go. BTW don't mix the wd40 trick with overly aggressive blowtorch in the air intake. Also take off the air filter for torching or Wd40. Wd40 is also good if you have old fuel that may not combust as easially. Also place a towel above the starter so that you don't drip Wd40 all over the electrical connections (spark) of the starter.
I've also found that with each successive attempt the engine warms up more and you may be successful on the 4th or 5th serious try. For this reason I will have the weaker person try 2 or 3 times to warm it up if it's cold or I think there might be problems, then I step in and look cool by starting on the 4th or 5th try.
Another trick if your battery is low is to immediately stop cranking. Go attempt to hand crank a few times and you can use what little juice is left in your battery to start her right up after you've warmed her up by hand.
It absolutely can be done reliably by an average person and once you develop a few techniques it becomes a very reliable way to start the engine. I've even gone on trips without an alternator or a starter.
A good time to practice, and get over the jitters some people have from hearing horror stories it so start her up by hand after a day of normal motoring. When warmed she'll start up immediately. Then try it on a warm day (on a cold engine) and then graduate to doing it on a cold morning. Try with and without Wd40
My new boat has a perkins that you can't hand crank. I DO miss the security of that little handle. Let us know how it goes!
MedSailor
PS it was so important to me that I always carried a spare bike chain and link key in a ziplock bag with grease.
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
Last edited by MedSailor : 05-13-2008 at 04:21 PM. Reason: correcting "some" of the mistakes
  #19 (permalink)
Old 05-14-2008
That was a truly excellent post. We will try again this weekend. For those who had no idea what we were talking about- here's picture of the engine:
I took that photo on my first meeting with the boat. I've since replaced the chain.
WHy Fairhaven? Anything to do with my hometown and the starting Point for Slocum's solo voyage?
In over my head?
  #20 (permalink)
Old 05-14-2008
Gary M's Avatar
Gary M Gary M is offline
Gary M is on a distinguished road
Yes it makes me want to run right down and crank on mine. well almost.
It was an excellent post and I will try it some time soon. I always knew it was theoretically possible just have never seen it done. Usualy after about two attempts I give up but repeated tries warming the engine, and me, tend to make sense.
Happy Cranking
Gary
Display Modes
vB code is On
Yanmar 2GM intermittent low power Northeaster Gear & Maintenance 21 07-31-2007 11:43 AM
Yanmar 2GM overheating Northeaster Gear & Maintenance 11 07-18-2007 03:07 PM
yanmar 2GM low cooling water volume?? Northeaster Gear & Maintenance 3 05-30-2007 11:02 PM
Yanmar 2GM or 2QM15...? marinesniper Gear & Maintenance 5 01-05-2007 06:45 PM
Yanmar 2GM zfactor Buying a Boat 2 08-06-2006 09:11 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
