Originally Posted by EO32
I'm 51, a little overweight, 225 lbs, 6 foot.
When I get the urge to workout, I tend to sleep until it passes.
I think the trick is how much fuel. I find that it will not start on full throttle, but 1/2 throttle.
It is a workout to get it started. It takes about 6 turns to get it up to speed, then drop the decompression while cranking and get the first compression to fire. I usually takes two or three tries.
I always used full throttle on the advise of the mechanic. BTW once you start it you might want to wander up to the cockpit and throttle down from 4000rpm in idle. Alternately you could shut it down after a few seconds with the decompression levers. Then do it again on 1/2 throttle.
BTW from your picture you'll never start the bugger. The top is missing from your Racor and you have air in the
line.
BTW someone asked about where to get a handle. Your yanmar dealer will have one and since it's a genu-ine yanmar part is should cost about 1/2 as much as your boat.
Crank away!!!
MedSailor
PS The boat's name when purchased by us was "Fairhaven" and yes, the PO lived in Farihaven WA (Bellingham).
