Volvo MD2 - SailNet Community
post #1 of 4 Old 06-07-2002 Thread Starter
Volvo MD2
I am considering buying a boat with the Volvo MD2. I have heard getting parts is very difficult. Any advice/experience?
Irwin32 is offline
post #2 of 4 Old 06-08-2002
Volvo MD2
I rebuilt my MD2B in ''98, ordering parts from Chase-Leavitt in Portland, Maine. I think they''ve gotten out of the parts biz, though. The parts came virtually overnight from Sweden. Not a problem.
VIEXILE is offline
post #3 of 4 Old 06-08-2002
Volvo MD2
I rebuilt my md2 3 years ago and had no problem getting parts. One thing though, Volvo parts are expensive. What I also did was to aquire a spare parts engine for the expensive large parts. I know you can still get just about anything from Volvo.
It is a good long lasting engine. Only thing is, the one that you are considering, does it have the dynastarter (2 belts) or a regular gear drive? The dynastarter is very$$$$$. Mine was rebuilt before I purchased the boat It still works fine , just takes a few rev''s to get it started.
Hope this helps
Also get the manual from Volvo
Dave R.
windancer1 is offline
post #4 of 4 Old 06-10-2002
Volvo MD2
One thing: Lessee, this was 4 years ago now. The manual, written by Swedish engineers, had some errors that slowed me down in my rebuild a few times. The big one was in determining how many 0.008" paper shims to put in under the jugs. You''re supposed to put in 4 shims and start tearing them out AFTER strapping across the jugs with a homemade jig and torqueing it down to spec (without the head on). You measure the remaining space at the top of the cylinder at TDC and you measure the amount the head hangs down into the cylinder and calculate the difference. This indicates whether you''re in acceptable parameters and tells you whether to remove or add shims. The point is to keep the valves from striking the piston. The manual had a figure of something like "the difference should be 0.37" or some such crap where the engineers misplaced a decimal point. I wound up just stacking 4 shims and calling it good after going through a dozen shims. Brain no work with head under sink for hours on end. She fine. Volvo parts expensive. Find a used MD2B for parts is good idea. Oh yeah. Copper oil lift lines that come up through the jugs become brittle. If you''re taking off the jugs anyway, replace both fore and aft lines. They WILL break. I did my rebuild in place. I had to undo the engine mounts and lift it slightly to access the the cover to the starboard side of the crankcase. I managed new bearings on the pistons. NOTE: Disconnect your shaft before you do this. There''s a vane of some sort in the transmission that WILL break, causing big problems. Have fun. Get a quote, just for the sake of looking at the guy that''ll do the work, and convince yourself that if HE can do it, YOU can do it....KW
VIEXILE is offline
Volvo MD 11C toalexan Gear & Maintenance 1 03-24-2010 11:32 AM
Volvo Penta engine rondezvous Gear & Maintenance 1 09-24-2006 12:24 PM
Volvo Prop Question mikehoyt Gear & Maintenance 0 04-01-2003 06:46 AM
Fresh Water Cooling Volvo MD17C Nereus32 Gear & Maintenance 0 07-17-2002 12:19 PM
Volvo 2001 Water Heater pmccann Cruising & Liveaboard Forum 1 03-02-2001 03:22 AM
