Old 05-12-2008
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
Spin/Whisker Pole
Does anyone have any experience building their own pole? I need a 14ft. (min) pole and having a hard time locating one short of buying new. I am considering buying the ends and then getting raw tubing to make-up a pole.
Anyone in the area know a yard that might have any used ones laying around?
Maeven
Tartan 34C Yawl #282
Anything-sailing.com
Moderator
Old 05-12-2008
I've found that it is often cheaper to buy a pre-made pole than to assemble your own from the parts.
Old 05-12-2008
...especially if you can find one in a marine consignment/used equipment store!
Hurricane areas should have lots of loose gear floating around somewhere!
1984 Fast/Nicholson 345
Old 05-12-2008
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Even if you can't find a complete pole, many boat yards, especially in racing areas, will have pole ends lying around someplace that you could fit to your own tube.
Many flash racers would rather buy a new pole than be bothered fixing a broken one.
Good luck!
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 05-13-2008
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
T
I was in Sailorman last week in ft L. I remember seeing spin pole ends. Didn't look closely but there was a selection.
I'm going to be in the consignment store in Ft. Pierce sometime between Sat & Tue. You could call them and I can confirm condition for you. I won't know much about the tech of a particular attachment tho.
There is a thread I made on this forum with a list of used & consignment shops. The one in Ft Pierce is on there.
Old 05-13-2008
jjablonowski's Avatar
jjablonowski is on a distinguished road
small-boat whisker pole
An article in the Fall 2007 issue of BoatWorks, entitled "An Inexpensive Whisker Pole," describes crafting an 8-ft. pole from an old boathook, using a Forespar spinnaker-pole hook (part # FP404002) and a bunch of 1-1/4-in. PVC pipe.
The whole affair is bolted together with dowels and mop handles for internal reinforcements. Used on a Precision 21. Author Clarence Jones contents total cost was "about $25, including the $16 mast ring (from Ronstan), but not including the boathook, which I already owned."
Old 05-13-2008
papasailor is on a distinguished road
reference to article?
I have a spinaker pole but will be racing in JAM this year and not sure about using the spin pole. The idea of a cheap (and no doubt) lighter whisker sounds good. Is there anyway to reference the article you mentioned on line or could you summarize how it was fabricated?
Old 05-13-2008
T34C's Avatar
Thanks Courtney.
I agree with SD- and Fast-, could be a pain, and expensive, to assemble my own unless I can get a great deal on the ends.
x- I will check into that option. Thanks.
Does anyone know of a store/yard that might have used pole(s)?
I have a small pole (8-10 ft.) from an old boat of mine. It has 1 broken end currently. Anyone have a Macgeiver solution for extending this pole and attaching the end that is currently broke? (Can't hurt to ask right? )
Maeven
Moderator
Old 05-13-2008
MIKEMCKEE's Avatar
MIKEMCKEE will become famous soon enough
Even though I hate to say it (west marine) has the end's of the pole you can buy and then attach them to the pole you have bought at the correct length.
Chief
s/v Blue Bayou
Old 05-13-2008
T34C's Avatar
Thanks Courtney.
x- I tried Marine Connection Liquidators in Ft.Pierce. (Is that the one you were talking about?) They didn't have anything. They are liquidators of manufactures overstocks.
Maeven
Moderator
whisker pole ?????? mangomike General Discussion (sailing related) 4 10-01-2006 08:05 PM
Downwind Passagemaking Mark Matthews Seamanship Articles 0 10-01-2002 08:00 PM
Setting the Spinnaker Pole Dan Dickison Racing Articles 0 06-19-2002 08:00 PM
Optimizing Your Downwind Performance John Kretschmer Seamanship Articles 0 04-09-2002 08:00 PM
Spinnaker Fundamentals Steve Colgate Seamanship Articles 0 06-24-2000 08:00 PM
