Blogs
User Name
  #11 (permalink)
Old 05-14-2008
brak brak is offline
Sea Slacker
brak is on a distinguished road
On some furling systems (mine included) line is attached by going through a hole tangential to the drum center and then a knot on the end. It would be difficult to imagine this coming undone. Also, consider that force on the line is proportional to size of the leverage, and since furling drum radius is much smaller than length of the sail, force on the line is proportionately less. It may be a significant force nevertheless, but hardly beyond what even a basic line can handle.
However, furling can certainly fail in variety of ways - no doubt about that.
  #12 (permalink)
Old 05-19-2008
ranger371 ranger371 is offline
ranger371 is on a distinguished road
Smile Furling Line Fun
I use Dyneema D2 Racing line on the Harken furler for my Beneteau First 456 and it works well. The only caveat to some of these hi-test lines (other than cost) is heat susceptability. If the wind get's hold of your genoa while you are deploying, and the line happens to zip out real fast, it can melt the jacket from the heat generated by friction in your deck fairleads, etc. (something I need to remedy with some more cheek blocks).
Good luck,
Mark
  #13 (permalink)
Old 05-19-2008
sailingfool's Avatar
sailingfool sailingfool is offline
Good luck,
Mark
CD,
Can we nominate Mark for a Lurker of the Year award. WOW, first post in five years, isn't his post some kind of record!!!
SF
CS 36T
Where are those skiis...
  #14 (permalink)
Old 05-19-2008
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
Extra turns on the drum: Absolutely!
I've only seen them burst from chafe, and then they burst like a gunshot. That nasty little line in the inconvenient place simply needs to be checked frequently, led carefully (to prevent chafe) and chosen well. Remember that some high-tech lines can saw through steel without chafing much--but they also will snap their own fibers if they are wound on a too tight a radius, typically something like 6x the line thickness may be the minimum they can be rolled into.
I would say to use steel cable with a fabric outer sleeve--but I also believe in never having lines that my knife can't part. Never know what they're going to get wrapped around. Or who.
  #15 (permalink)
Old 05-19-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
HS-
You just need a better knife...
If you're new to the Sailnet Forums... please read this POST.
  #16 (permalink)
Old 05-20-2008
TOMINDC2 TOMINDC2 is offline
Old Navy
TOMINDC2 is on a distinguished road
We have both a screacher and a genoa. I keep 4 or 5 pieces of new line scraps aboard. In case of a blow, I tie off the furlers at their base to a stanchion in order to prevent swiveling in either direction. I tie a line around the furled sail at chin height as well. It is sort of like wearing suspenders and a belt -- leaving nothing to chance :-)
CAPT Tom
KatMan2 #992
Gemini 105MC
  #17 (permalink)
Old 05-22-2008
captmikem captmikem is offline
captmikem is on a distinguished road
I replaced the wire on an Alden 54 with Rekman furling gear with a light Kevlar line. The wire was always getting meat hooks in it and was causing problems. The Kevlar with a Dacron covering was small and light. I had to splice a larger line to it after enough was used to wrap the drum as it was too small to handle, I spliced 7/16 inch Dacron, which gave a good purchase to grab. I could put this on a winch and ease it out easily, or luff a bit and bring it in with a winch. All in all it worked very well. I did the same with a 42 foot HR and again had no problems with it.
  #18 (permalink)
Old 05-22-2008
Kevlar line isn't really a good line for this purpose, since it doesn't deal with bending and compression all that well IIRC. A Dyneema or Spectra based line would probably have been better, stronger as well too.
Display Modes
vB code is On
How to make a furling line? MelSnyder Gear & Maintenance 5 06-22-2007 08:13 AM
Getting Good Starts, Part Two Zack Leonard Racing Articles 0 01-15-2004 07:00 PM
Getting Good Starts, Part One Zack Leonard Racing Articles 0 12-18-2003 07:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
