Old 05-13-2008
duffer1960's Avatar
Catalina 38 Avantura
duffer1960 is on a distinguished road
Refinishing dinghy floorboards; what to use?
The old finish on the plywood panels that make up my dinghy floorboard are in serious need of refinishing. The wood is still in good shape; the finish is flaking off and non-existant in some areas. What would be the best finish to use? Looks aren't a concern, just protection from the elements. Thanks.
Sincerely,
Russ Duff
Catalina 38, Hull #112
"AVANTURA"
Lake Erie
Grosse Ile, Michigan
Old 05-13-2008
peikenberry's Avatar
peikenberry is on a distinguished road
An EPoxy Resin like West Or SystemThree. It will give you a nice finish and seal the wood.
Ike
My Boat building Web Site
My Boating Safety Blog
Dont Tell Me that I can't. Tell me how I can!
Old 05-13-2008
fishboyneil is on a distinguished road
I've given mine a good sanding and then put on a couple coats of interlux brightside polyurethane with decent results. They do need a recoat every year or two. The brightside stands up pretty well to being consistenly wet (bottom side of boards). I also added some grip spheres(could also use sand) to the second coat on the topside. Without the boards are pretty slick when wet (splash and loss of beer in hand).
Old 05-13-2008
duffer1960's Avatar
I was thinking of using epoxy, but I thought it wasn't UV resistant, and therefore wouldn't hold up in the sun.
Sincerely,
Russ Duff
"AVANTURA"
Lake Erie
Old 05-13-2008
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Epoxy will eventually breakdown under sunlight (UV) although it is a good waterproofing treatment. If you used a decent marine paint or coating (Brightsides was mentioned) over the epoxy coating that should hold up longer.
Good luck.
Old 05-13-2008
JimsCAL's Avatar
JimsCAL is on a distinguished road
If the finish is natural, not painted, then some good quality spar varnish is worth considering. The boards in my Achilles came with a clear finish and a light sand and coat of varnish each spring has kept them looking like new.
Old 05-13-2008
LarryandSusanMacDonald's Avatar
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald will become famous soon enough
If you NEVER want to refinish them again, replace them with Starboard, a polymer material. It comes in various colors and thicknesses. It's not cheap - but it will last forever. It's impervious to everything except atomic explosions, shark attacks, and idiots with power tools.
I used it to replace the slats in my first dinghy - not a whole floorboard, just stiffening slats, but it worked great. I've seen it used for just about everything - the only drawback is that there is no adhesive that will hold on the stuff.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
Old 05-13-2008
Ultimate sole is a good product for refinishing the boards. Not slippery when wet... looks fairly good too.
Old 05-14-2008
duffer1960's Avatar
What about a clear polyeurethane?
Sincerely,
Russ Duff
"AVANTURA"
Lake Erie
Choosing a Dinghy Sue & Larry Gear and Maintenance Articles 0 10-11-2004 08:00 PM
Choosing a Dinghy Sue & Larry Cruising Articles 0 10-09-1998 08:00 PM
