Old 05-13-2008
lbdavis's Avatar
lbdavis is on a distinguished road
Mast boot tape, what am I missing?
I bought a roll of mast boot tape from WM. When I tried to apply it, the tape appeared to have no adhesion at all. Is there some type of catalyst I'm missing here? Heat?
Old 05-13-2008
knothead's Avatar
The mast boot tape is just like rigging tape. I think it is called self-amalgamating. It only sticks to itself.
It can be stretched up to 6 times it's length and then when pressed to itself it sticks.
Ron Paul 2012
"wikijar"
Old 05-13-2008
ASA and PSIA Instructor
As KH said, the tape sticks to itself, BUT you have to stretch it adequately to active the stickness, check the box for instructions...
Old 05-13-2008
lbdavis's Avatar
huh?
It actually came with no box. Just a little tag with no pertinent information on it.
I tried the stretch thing. Maybe I need to stretch it more...
Thanks!
Old 05-13-2008
I'd rather be sailing
labatt will become famous soon enough
Pick a spot on the mast to start from. Have someone hold the end there. Stretch it until it becomes approximately half it's normal width and keep wrapping it over itself. It will adhere to itself, fuse and become one mass over a few minutes.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 05-13-2008
ericsmith3d is on a distinguished road
I've never used it, but I would imagine that starting from the bottom and working up would be better, the overlap would be like the shingles on a roof.
Old 05-13-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
I had the same problem with that kind of boot tape,someone here ( I think it was Freesail ) at sailnet suggested some kind of roofing tape ( I think that's what it was ) from HD; I tried it and it has worked great so far, and it's been since last fall..........
I also had my canvas guy make a real nice mast boot cover,so it looks pretty clean
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 05-14-2008
lbdavis's Avatar
Hmmmm
I tried stretching the Hades out of that tape this evening with a second set of hands and had no luck. Friggin' West Marine...
I would like to have a nice boot made up, but I'm not un-stepping my mast until next fall - at the earliest...
Old 05-14-2008
Can you post a photo of the tape and box. It might not be the self-fusing tape everyone is thinking it is...but without a photo...can't really help you.
Old 05-14-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
I have said it before, I have used ice and water shield, and I think it offers far better protection and seals better. From their website:
Grace Ice & Water Shield®
The leading self-adhered roofing underlayment, Grace Ice & Water Shield offers premium leak protection for sloped roofs in climates subject to ice dams and wind-driven rain. It is applied to the roof deck prior to the application of the finished roof covering, which is most often shingles but can also be tile or metal. The membrane goes under shingles and seals around nails that hold the shingles in place, so water that doesn't drain properly cannot penetrate the roof. It also creates a weather-tight barrier against wind-driven rains that cause shingles to lift and leak. Affordable and easy to install, it provides added peace of mind for many years, even in the most brutal winters.
S/V Scheherazade
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
Southern Cross 31? db27513 Boat Review and Purchase Forum 35 09-24-2007 10:58 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
