Old 05-13-2008
jaschrumpf's Avatar
1975 Newport 28
jaschrumpf is on a distinguished road
Fuel tank gauge/float
The fuel gauge on my boat won't read above 1/4 full. It was working OK last season, but now when I turn the key it won't rise above that level no matter how much gas is in the tank. I'm not even sure it would read less than that level, either. A friend told me that if the gas was "varnished" at all it would coat the sensor so that it wouldn't send properly.
Is this problem more likely the gauge or the float sensor? If it is the sensor, are those things generic for gas tanks or do you have to get one that specifically fits the tank? Obviously the gauge would be no problem to replace.
Thanks!
Old 05-13-2008
It depends on the type of sender. If it uses a float...the float may have developed a leak and may not be "floating" as it should be.
Old 05-13-2008
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Sd's point is valid...most old float's were hollow either mettle or plastic...most new floats are a solid composite of sorts...they dont get pinholes and fill up any more...as to your question yes you can buy a generic sending unit and install in your existing hole...bolt patterns are/were pretty standard...just bring it in with you to the store ,you will find a match..
You will find them sold with long arms that will require you to measure the depth of your tank and cut/bend following the directions...
As far as you friend's notion of shellacking...??? All new types have enclosed potentiometers..this is not going to happen...
This is an hours job at most..
Replacing my fuel tank this Spring, and need your sage advice. ChicagoNewport27 Gear & Maintenance 12 06-04-2008 07:39 PM
Diesel Fuel Tank Woes...or Bonehead mistake of the season rperret Gear & Maintenance 9 10-07-2007 09:32 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 07:00 PM
