Old 05-13-2008
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
2GM Fuel Pump Damage
While working on my fuel tank replacement project I've been finding
some other issues. While replacing the tank I've cleaned/rebuilt the
Racor 500FG, replaced all fuel lines with new (except HP fuel lines on
the engine), cleaned the bilge, and was going to inspect the Yanmar fuel pump.
Here's where the fun starts. When I took the fuel pump off I found the
casing to be cracked severely. It was cracked on the flange that mates
to the engine block. The pump has an arm that goes from that flange
area into the engine block and rides on a cam. As the cam rotates the
arm moves up and down, this is what causes the pumps diaphragm to move
up and down.
Pump Lower Casing Cracked
View of Crack From Fuel Pumps Operating Arm Flange
The good thing was that the marina next door had two replacement pumps
and associated gaskets in stock, and they were 70% off on top of that.
I got two $80 pumps for about $20 each the very day I needed them! One
went on the engine and the other in my spares stock.
With the new one on I decided to see just how this puppy works and
took apart the old damaged pump. What I found inside was scary. The
upper casing of the pump has an inlet valve, an outlet valve, a
fitting that keeps them in place, and two little screws to attach the
valve keeper. I found the valve keeper had failed and broken in two
pieces, the outlet valve was almost fallen out of place, and one of
the valve keeper screws out. The screw and broken piece were "floating
around" inside the pump beating the hell out of the diaphragm. If they
had broken the diaphragm, it would have filled the lube oil sump with
fuel oil by flowing down through the valves operating arm flange.
Pump Internal Damage
Loose Pieces Inside Pump, Damaging Diaphragm
That was a close one. The engine has run like this for who knows how
long. Give your engine a good look over.
Dictated, but not read.
Old 05-13-2008
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Good find Sapper...Hard to believe it wasent leaking oil in the bilge.
Old 05-13-2008
if the diaphragm had worn through it would have for sure. I was surprised the damn thing even worked at all.
Old 05-13-2008
Sea Slacker
brak is on a distinguished road
amazing, and the pump does not look particularly old otherwise. how old is the engine?
Old 05-13-2008
1983, as far as I can tell it's the origional pump. The flange gasket was uh... "powdery" and cooked to the engine block and flange face. It looked old.
Old 05-13-2008
Sea Slacker
Wow. The paint looks pretty good for 1983 engine (sorry, offtopic but this is my current issue - engine paint begins to bubble in places, rust shows through - not sure why, as the compartment is dry)
Universal M21, long story and fuel line question BarryL Gear & Maintenance 16 05-12-2008 03:37 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
