Adler Barbour Troubleshooting (LED Flash) - Page 2 - SailNet Community
post #11 of 17 Old 05-16-2008 Thread Starter
FortAwesomeIII's Avatar
Thanks for all the replies!
The Supercoldmachine is air and water cooled. There is a switch that turns the water cool option on, but I never keep it on because it works quite adequately sans water. Turning that option on does not change anything.
I guess I will have to remove the sink regardless to check everything out, even to clean the condenser coils.
As of tomorrow, the unit will have been turned off for another week, so I am interested in seeing if I get any cooling when I turn it on.
Thanks again for any input, and I will report my findings.
John Pate
Highport Marina ZD27
aboard S/V Fort Awesome III
"I couldn't do the things the way those people do.
I couldn't live there if you paid me to. "
The Talking Heads
FortAwesomeIII is offline
post #12 of 17 Old 05-17-2008
Grasshopper
JiffyLube's Avatar
Why not check out this link at koolmann-marine...sounds like your problem.
kollmann-marine.com :: View topic - Error 3 Control Danfoss DB50
JiffyLube is offline
post #13 of 17 Old 05-19-2008
Has anyone heard from FortawesomeIII?
denby is offline
post #14 of 17 Old 05-20-2008 Thread Starter
I thought I posted on here Monday, but I guess I didn't submit it right.
Jiffylube, thanks so much for the link. That site appears to be exactly what I need.
Thanks again to everyone else that responded. I have not had a chance to in-depth trouble shoot the unit according to some suggestions on the kollmanmarine site, but after having it off for over a week then restarting it, all I get is the fan coming on. It is looking like I will have to pull the sink and the whole unit regardless. I will keep my progress posted!
John Pate
The Talking Heads
post #15 of 17 Old 05-28-2008
Is it repaired yet?
denby is offline
post #16 of 17 Old 06-02-2008 Thread Starter
OK, here's a progress report... The info at kollman-marine.com was incredibly valuable at determining my problem:
Looks like after testing the input voltage(OK, 12VDC or above), Fan(OK, will cause start abortion if drawing above 1 amp), and compressor(OK, the Danfoss unit should have the same resistance between all pins and have an open circuit between the pins and compressor body), it seems that the DB50 control module is faulty. From my limited research, It looks like the module is about $350. A new supercoldmachine is a little less than $800. I went ahead and ordered a new unit just to be sure everything will be operational. In my opinion, the compressor and the rest excepting the control module is good. If anyone has a unit with a bad compressor or other problem that could still have a good module, I would be interested in buying it.
Also, I ordered a 31Q Waeco Drawer fridge that I am going to install in an unused place to further increase my cold storage capacity. I have a 14Q Engel Deep Freeze that works great for meats, frozen drink mixes and such. I will use the drawer fridge for cheese, yogurt, or any other refrigerated food item, and I am going to use the existing fridge with the new Super Cold Machine for beverages only. I've got some starboard that I plan on dividing the fridge up with. Previously, I have had a LOT of room in the fridge but only a portion was usuable due to the layout. I'm planning on maximizing the room with the division.
Thanks everyone for the help!
John Pate
The Talking Heads
post #17 of 17 Old 06-02-2008
Grasshopper
JiffyLube's Avatar
While you were checking out the kollman site I was searching for a module for my older coldmachine...since Alder Barbour doesn't make mine anymore. I found the site for Frigoboat that shows the module that I'm looking for Frigoboat Home Page , and it cost $225.00. There is another site by Coastal Climate Control that is affilated with Frigoboat that tells more about the module Coastal Climate Control: Control module 12VDC 4-pin for all Danfoss BD3 and earlier compressors . This module is a 12VDC 4-pin for all Danfoss BD3 and earlier compressors.
LEDs afloat GoodOldBoat Good Old Boat 56 12-19-2014 01:23 PM
Adler Barbour refrigeration Fro36 Catalina 10 08-13-2010 08:42 AM
Adler Barbour maintenance ZapataII Gear & Maintenance 5 05-07-2008 12:01 PM
Charging an Adler Barbour Refrigerator maxheadspace Gear & Maintenance 6 10-16-2007 07:46 PM
