Old 05-15-2008
knothead's Avatar
Mechanical Rig Fitting Photo
Here is a couple of photos of a Norseman eye terminal for those who think that mechanical fittings don't have the same corrosion issues that swage terminals have.
Ron Paul 2012
"wikijar"
Old 05-15-2008
erps's Avatar
the pointy end is the bow
Doh!
How old is that fitting?
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 05-15-2008
knothead's Avatar
Originally Posted by erps View Post
Doh!
The owner wasn't sure. He guessed 10 to 15 yrs.
Ron Paul 2012
"wikijar"
Old 05-15-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Type 304, maybe not type 316 or 316L ?
S/V Scheherazade
Old 05-15-2008
Sea Slacker
brak is on a distinguished road
Wow, that does not look good. I have a mechanical fitting inside my furler (which is made in mid-70s), I wonder what it looks like inside. The eye outside looks fine, and rigging company was able to use it with a new forestay, but the heck I know.
Old 05-15-2008
Maine Sail's Avatar
It's possible...
It's possible that fitting was put together with Silicone which has acids in it and are not good nor recommended for stainless mechanical fittings. It looks like crevice corrosion though..
______
-Maine Sail / CS-36T
Old 05-15-2008
knothead's Avatar
It's a Norseman. 316 stainless
My policy is to advise against using old mechanical fitting when fabricating a new piece. Why take a chance.
If I remember correctly, this fitting was dry when we took it apart.
It was awhile ago though so I'm not 100% sure.
Ron Paul 2012
"wikijar"
Old 05-15-2008
Was that assembled with locktite, as is recommended by most of the major mechanical fitting manufacturers. It doesn't appear so. Loctite would probably have helped keep salt water from intruding and causing the crevice corrosion seen in the photos.
Old 05-15-2008
Sea Slacker
Because it is a fitting that is built into the furler and cannot be removed, if I understand it correctly. To replace it I need to replace the entire furler - and since it is a system out of production, that means drum, foil and everything else. (And I doubt I'll get a furling system as sturdy as that one today - at least not for a price compatible with my budget )
Old 05-15-2008
knothead's Avatar
Many of the Hood and Selden furling systems have integral mechanical fittings.
All you can really do is inspect it carefully and as SD says make sure you use Loctite or other thread locking compound and the proper sealant.
If a competent rigger was responsible for replacing your head stay. I wouldn't lose any sleep over it.
Ron Paul 2012
"wikijar"
Ketch vs Sloop? bobmcd Boat Review and Purchase Forum 24 05-11-2010 03:35 AM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Sloop or Ketch? maxheadspace Boat Review and Purchase Forum 46 07-27-2007 02:56 PM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
