Fair Warning - Page 4 - SailNet Community
post #31 of 39 Old 05-15-2008
Tom—
It could be the original rigging, and it might be fine... on my friend's C&C 38, the rod rigging is over 30 years old...and fine as far as anyone can tell.
But if you were going to go on a long voyage, where you'd be far from help and easy access to modern facilities and supplies, then you would probably want to either carry enough replacement gear that you could exercise repairs in the case of a failure, or have the rigging replace before leaving.
sailingdog is offline
post #32 of 39 Old 05-16-2008
Courtney the Dancer
jrd22's Avatar
We have just removed all of our chainplates on a 1988 Brewer, they looked fine but it's what is between the decking where you find the problems. We had at least three out of the twelve that definitely had visible small cracks where they passed through the deck. You would never be able to dye test this area of the chainplate to test without removing them. Being twenty years old and having spent at least a couple of years in the south Pacific we felt it was important to pull them; I'm glad we did. I made the new ones myself from 3/8 X 1 3/4 316SS, which is a bit larger than the original. Had them polished and they are ready to be installed next week. Fortunately the boat was built so that they were relatively easy to replace, only very minor destruction of the interior (and two days for two people). The rigger I consulted said that chainplate failure is the #3 reason for dismasting (not sure what #1 & #2 are).
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #33 of 39 Old 05-16-2008
Sounds like you're making progress, John!
Will you be launching "Blue Moon" soon? No doubt this cold spring has held you up some....
Faster is offline
post #34 of 39 Old 05-17-2008
Sea Slacker
Well, I took a long look at my chainplates today. The parts above deck seem to not have any cracks that I can see (though the hole deformed ever so slightly, it is impossible to see the change in shape, but touching its edge with a finger I can feel the top edge slightly wider - I guess this is due to the size difference between whatever (13mm?) metric hole and 1/2" pins that were used there for its entire life, or may be it was meant to be that way).
Anyway - I am not sure how much this means. I also replaced turnbuckles from AlexanderRoberts with Hayn. If anyone is interested in a set of not quite 8 month old turnbuckle bodies with toggles (lower toggle only) for 1/2" pin - let me know, I will have 6 or 7 of them for sale pretty soon
brak is offline
post #35 of 39 Old 05-17-2008
Brak-
If the holes are elongated at all, the chain plates were probably point loaded with a clevis pin that was too small for the hole. This will often lead to the formation of a stress crack at that point... This is one reason that it is very important to use the proper size clevis in a chain plate or tang.
How old are the chainplates?
post #36 of 39 Old 05-17-2008
Sea Slacker
As old as the boat - 36 years and counting. They are most certainly somewhat point loaded since they are drilled for metric pins and boat was, at least for the last 20 years or so, used with US hardware (i.e. 1/2" pins). The difference is not much but certainly exists. I specifically looked around that area and found no cracks. I also looked again at how chainplates are attached and now I am certain that the only way I could justify replacing one is outright failure. It's a short rig which pretty much can be held up by just one or two shrouds anyway
Incidentally, there is a weak point in it - essentially a potential single point of failure, but it is not the chainplates (and I am thinking of a way to remedy that, though it would probably entail moving spreaders which I am not looking forward to either).
brak is offline
post #37 of 39 Old 05-18-2008
I'm all for exterior chain plates. Certainly if they have to be stainless.
When stainless is starved - oxygen-wise - you have to take crevice corrosion into the account. This is the reason one shouldn't use stainless under the waterline, unless it's a boat that is most often on a trailer.
[apparently I'm not allowed to post direct links :-( Anyway, copy/paste this into your browser:]
azom.com/details.asp?ArticleID=1177
(it's a good explanation of crevice corrosion and how it adheres to stainless).
Now, If I had to have inboard chainplates, especially with a high stress modern rig (as opposed to a low-stress gaffer or lugger) I would take the chainplates apart, and if they're fine, I'd cover them with lanolin, before screwing them together and then keep replenishing them with lanolin at the top.
I wouldn't skip the taking them off the boat-part, because then your "fix" might actually do more harm than good: Starving the stainless even more.
Bagger is offline
post #38 of 39 Old 05-18-2008
chucklesR's Avatar
FWIW, there are a few companies that do ultra sonic and eddy current NDT (non destructive testing) of stainless primarily for the aeronautical industry. If it's cost effective to test that would be the absolute best way. You'd most likely have to pull the parts and take it to them.
I'd also think that thermal imaging might be a better than nothing option for chainplates embedded in fiberglass - corroded steel heats differently than sound steel.
chucklesR is offline
post #39 of 39 Old 06-03-2008
Here is a link to an interesting article about checking the integrity of chain plates you cannot see.
http://www.irwinyachts.com/Drawings-...hainplates.pdf
Fair winds
LakeEscape
LakeEscape is offline
A word of warning about an Annapolis broker ursu Boat Review and Purchase Forum 8 10-17-2006 10:17 PM
Word of warning about an Annapolis Broker ursu General Discussion (sailing related) 0 01-01-2001 10:01 AM
Radar Proximity Warning Systems Jim Sexton Seamanship Articles 0 10-31-1999 07:00 PM
Radar Proximity Warning Systems Jim Sexton Gear and Maintenance Articles 0 10-31-1999 07:00 PM
Radar Proximity Warning Systems Jim Sexton Cruising Articles 0 10-31-1999 07:00 PM
