Blogs
User Name
  #11 (permalink)
Old 05-15-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Be aware that a lot of the numbers, even those supplied by the manufacturer, were often off by a good amount, and they often changed during a given boat's production run to some degree.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
  #12 (permalink)
Old 05-15-2008
Sailormann Sailormann is offline
Here .. Pull this
Sailormann will become famous soon enough
I would think that mast designers would take this into account and build them to handle such loads.
They do. Don't panic.
  #13 (permalink)
Old 05-19-2008
amayotte amayotte is offline
amayotte is on a distinguished road
So the idea of putting a tube in the mast to counter compression forces is more for a peace of mind?
The reason I ask about this is because mine does not have a compression tube and I am a little worried that I will crush the mast in hard wind.
In fact my system is fairly flimsy. It is a floppy system which I want to replace with some rigid spreaders.
Does anyone know of how to determine what type of mast I have in order to properly order new spreaders and brackets.
Thanks,
Adam
  #14 (permalink)
Old 05-19-2008
Amayotte-
It would help if you said what kind of boat you had.
  #15 (permalink)
Old 05-19-2008
knothead's Avatar
knothead knothead is offline
Rigger
knothead will become famous soon enoughknothead will become famous soon enough
Thanks,
Adam
Hi Adam, There are as many ways to attach spreader to mast as there are mast manufacturers. Some are better than others.
Some have bases that are welded on the outside, some have wraparound brackets, some have a slightly bent solid aluminum bar stock inserted through slots in the side of the mast that the spreaders slip over and are pinned in place with clevis pins.
The manufacturer of your spar probably thought about what they were building. That doesn't mean that they did a great job and it doesn't mean that what was maybe a good setup 10 years ago isn't in need of rebuilding.
I use compression tubes a lot. If I add a boom bail, I'll use a compression tube. Same thing if I am bolting on a set of tangs, but if a spar has in-mast furling, then a compression tube won't work.
It would really help if you could post some photos of the fairly floppy system so we could see what kind of system it is.
Steve
SSMR Inc.
"wikijar"
  #16 (permalink)
Old 05-19-2008
My boat is a Chrysler 26.
The spreaders are tube type and it looks like they are connected using a small bolt.
I don't have enough posts yet to provide links or images...but soon I will.
Thanks for all the help,
Adam
  #17 (permalink)
Old 05-19-2008
almost enough posts...
  #18 (permalink)
Old 05-19-2008
Here are some images, but there isn't a very good pic of the spreaders.
I will try and send some in a few days.
Picasa Web Albums - Adam - RaisingMast
  #19 (permalink)
Old 05-20-2008
knothead's Avatar
Rigger
What's wrong with this picture (installation)?
Steve
SSMR Inc.
"wikijar"
  #20 (permalink)
Old 05-20-2008
Ya I know.
I have just bought the boat and spent the weekend working on getting the mast up.
I had to do it by hand, so it wasn't easy, and once I got it up I was hurrying to hook up the forestay and forgot about the furler. I decided since it was just for the weekend I would leave it the way it is.
Any ideas on what type of mast was used by chrysler and which type of rigid spreaders would work?
The one thing that boggles me a little is that in order to counter compression people drill holes through the mast, at the half way point, and create a weak point in the mast. Doesn't make sense to me.
Oh well, I'm obviously not an engineer.
Thanks again,
Adam
Display Modes
vB code is On
Re: Angled Spreaders Sailormann Sailboat Design and Construction 10 05-05-2008 05:04 PM
Spreaders sailaway21 Gear & Maintenance 7 04-03-2007 07:26 PM
Best wood for spreaders? Tree_hugger Gear & Maintenance 1 07-10-2004 06:52 PM
Swept back spreaders monark192 Gear & Maintenance 6 04-10-2002 05:29 AM
WANTED: Hobie 18 Spreaders James Long Gear & Maintenance 1 09-08-2001 05:19 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
