Blogs
User Name
Old 06-10-2002
halyardz halyardz is offline
halyardz is on a distinguished road
Head Refurb or Buy New?
I''ve got an older Wilcox-Crit head on a 1980
boat. Should I go with the refurbishing kit or just buy a new replacement? It is currently working OK but am getting a bit of water from the top of the pump shaft. Those gaskets have to be tired.
Old 06-10-2002
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
If all you are getting is a little water at the pump shaft, it is cheap and easy to simply replace the packing seal. The last boat that I owned had a really basic Brydon-Boy, which was not a great head, and it was fine after 17 years, except for replacing pump shaft seals. The Wilcox Crit''s are higher quality heads and are expensive to replace with an equal quality (not that the rebuild kits are cheap).
Old 06-18-2002
Starlite Starlite is offline
Starlite is on a distinguished road
A replacement seal for the Wil-Crit is a pretty inexpensive repair. I too, had a 30+ year old Bydon Boy, which the pump and joker were completely shot. It was $50+ for the full rebuild kit, but I found a new replacement Wil-Crit for $99. Used the opportunity to do a complete rebuild of the head (new flooring, hoses), but it turned ito quite a project.
Display Modes
vB code is On
What''s the best toilet (head) and... Myblueheaven Cruising 2 10-04-2003 09:52 AM
Head installation Irwin32 Gear & Maintenance 4 03-20-2003 12:23 PM
Rudder head corrosion aflanigan Gear & Maintenance 3 01-27-2003 01:01 AM
Control Head fix for Merriman Steering System tdp Gear & Maintenance 0 08-12-2002 05:07 AM
Head Problems bootsy1962 General Discussion (sailing related) 3 02-19-2002 07:26 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
