Going Up the mast - Page 10 - SailNet Community
post #91 of 106 Old 07-03-2008
Originally Posted by Gary1 View Post
Now you're ready to work on the lights. Oops. You can't reach them sitting in the boatswain's chair. What to do?
This is where you have to raise a second halyard with a couple of loops firmly attached so you can stand up in the loops. If you think you're going to have to do this, try it about a foot off the deck first. Don't be forty or fifty feet up to try something new. This has a second problem. You'll need to be able to do the entire job with only one hand, because you'll be holding on to the mast with the other hand. For myself, I made my own boatswain's chair and it fits my scrawny self very closely.
Cap'n Gary
Wow, A lot of very practical info in your post.
It's obvious that you've done a lot of work aloft.
About getting above the top of the mast. You make a set of stirrups to stand in with an extra halyard. What I do is basically the same idea but I attach the adjustable stirrups to the same attachment point as the chair and have a readily adjustable waist strap so that when I stand and lean back I am able to use both hands to work.
The waist strap is very handy just for bracing and positioning myself and the stirrups are a break for the back after sitting in the chair for awhile.
Thanks for the great post.
knothead is offline
post #92 of 106 Old 07-05-2008
Sea Slacker
this weekend I finally got to the top of the mast. MastMate is excellent, easy to use (testament to which is the fact that I went up and down 3 times and didn't break a sweat), and didn't need anyones help either.
One thing that was important is to furnish a proper chest/shoulder support. I used two lengths of climbing webbing with carabiners (two so that I would always stay clipped on even when going around the spreaders or around upper shroud fittings on top).
This is what mastmate looks like when raised. It helps to pull down and straighten steps as you go up the first time (the photo is taken after first ascent)
These are two pieces of webbing I used for shoulder/chest support. I ran both behind my back under arms, up around the shoulders, crossed on the back and under arms forward again. This creates good support where needed while still leaving enough slack to work on ends of spreaders (which I had to do again, as a piece of nylon thread I used to raise items up above fell and got caught on one)
This is what climbing the ladder looks like - I used a shoulder bag (diaper bag actually ) to carry tools. Blurry image courtesy of my old camera.
I found that it was most convenient to stand with one foot in the loop above and one below, that way I was able to move my weight from one foot to the other periodically - this definitely helped avoiding fatigue. I only stood up in both upper loops intermittently when I had to take a good look above the masthead.
Obligatory photo with my feet This is taken from spreader level. I went up to spreaders two more times - it's so easy.
One more thing - wear comfortable pants that do not restrict your step, for easy climbing. On the first attempt last week I tried going up in shorts that are somewhat limiting - and it was inconvenient. I think this is where reports of "steps being too far apart" come from. If you are in a remote cove somwhere - I guess you can go up naked
So, that's my review. YMMV.
brak is offline
post #93 of 106 Old 07-05-2008
I bought the MastMate but my size 11 feet wont fit the step and I cant do it bare foot. may be some of them pointy toed boots?
badsanta is offline
post #94 of 106 Old 07-05-2008
Sea Slacker
Really? I wear size 10, but those loops are huge - I can't imagine any feet being too big, well may be Shaq's but he won't need MastMate, he can just stand up and reach the mast head Proper shoes seem to be important - I found that my "keds" with rubber sole work best.
brak is offline
post #95 of 106 Old 07-05-2008 Thread Starter
1977 Morgan OI 30
Joesaila's Avatar
Lots of great tips here...went up last week twice using halyards, bosuns seat and mast winch. It was easy but required two. Changed and cleaned a couple of bulbs but will change them to leds soon. Like the suggestion of the webbing for that extra two feet so I can actually be above the mast.
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Joesaila is offline
post #96 of 106 Old 09-18-2008
jarcher's Avatar
For people who don't plan to go up the mast often, is there a less expensive option than buying a bosun chair?
jarcher is offline
post #97 of 106 Old 09-18-2008
climbing harness from rock climbing store.
sailingdog is offline
post #98 of 106 Old 09-18-2008
jarcher's Avatar
Thanks SD!
jarcher is offline
post #99 of 106 Old 09-18-2008
glad to help... try them out though...some are better than others.
post #100 of 106 Old 09-19-2008
I don't discuss my member
zz4gta's Avatar
Check out Backcountry.com got my climbing harness from there, they also have ascenders. A LOT cheaper than bosun's chairs. And personally, I like the "strapped in" feeling I get while I'm in the harness. My skinny butt tends to slide around in bosun chairs, makes me feel like I'm going to fall out. In the harness, you can go complete inverted and relax all muscles, and you don't come out of it. Gives me that warm, fuzzy feeling. And the attachment to the climbing harness is right at your waist/belly button, so you don't need to stand on loops. Using the main halyard, I can get the top of my mast, chest high with someone grinding and have the use of both hands.
The best part, they're about $50 or less.
Merit 25 # 764 "Audrey"
zz4gta is offline
Southern Cross 31? db27513 Boat Review and Purchase Forum 36 09-02-2016 12:48 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 08:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 01:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 06:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 07:08 PM
