Going Up the mast - Page 9 - SailNet Community
post #81 of 106 Old 06-28-2008
Originally Posted by brak View Post
Easily got to the spreaders and was able to finally fix lose tape on a spreader boot. It is actually possible to get to spreader ends (with one hand at least) from the ladder, if the chest loop around the mast is sized right.
So what you did was lean out from the ladder and reach for the spreader end? Hmmm... That sounds... uncomfortable.
I've got the same problem, with tape coming loose on one of my spreader boots, but I'm thinkin' the TopClimber would be better for that. I think I'll re-read this thread. I'm verging on trying to talk the Admiral into letting me get something to get up the mast. I was leaning toward the Mast Mate, but now I'm leaning more toward the TopClimber.
Jim
SEMIJim is offline
post #82 of 106 Old 06-28-2008
Sea Slacker
Jim
Actualy it was reasonably comfortable. The chest/shoulder belt held me at an angle to the mast, and I could swing out as needed. It was certainly more comfortable than my past attempts at using various climbing harnesses to lift myself. YMMV of course. What helped me is that I was more in control of my position than I was while hanging at the end of the halyard in a harness. I did a few climbs up and down (with different chest belts, to try them out) - on the climb when I actually fixed the spreader boot I still held with one hand to the mast and had to do it single-handed, but on subsequent climbs I was able to swing out and get both my hands in a general area (well, one was still closer than the other). Another plus so far - I did 4 climbs in 90 degree heat and wasn't too terribly tired at the end. A previous attempt at using ascenders left me with a sore hand for the day and unable to do much else (but these were regular ascenders, not topclimber)
That said, I hope to have a real opinion only when I get to the mast top (But if I bought mastmate a month earlier I would have saved a cost of paying my marina to replace the masthead light, and at their prices the thing would half-pay for itself by now ).
brak is offline
post #83 of 106 Old 06-29-2008
Jim
If you guys are going to use a ladder to climb the mast, then why not affix some suspenders to your bosun's chair and wear it while you climb. Attach it to a halyard and have someone on deck tail and secure it when you are where you want to work. Then you can swing out to the spreader tip and free up both hands.
knothead is offline
post #84 of 106 Old 06-29-2008
Sea Slacker
I thought about using a harness with halyard as a safety. I am pretty sure I'd be uncomfortable (as in - scared) hanging in it to do anything, but as a safety it may be a good idea.
Two problems though - it would get in the way (I found that anything in front of me can, if not placed properly) and, more importantly, I don't have any spare halyards to use And no winches to raise a spare halyard either. The two winches are taken by furled genoa and main halyards.
brak is offline
post #85 of 106 Old 06-29-2008
If you don't have a halyard then there's not much you can do. And if hanging in a chair bothers you, it probably won't after the first few times. But the lack of winches doesn't really matter. You are doing the climbing. All the person on deck has to do is take up the slack and tie off when instructed. A cleat or any strong point will work for that.
When I am working on a boat with mast steps, that's what I do.
As far a the chair getting in your way, I'm not sure what you mean. It would simply be hanging off your shoulders and back. You sit down in it when you are tied off. It's not in front of you at all.
On another note. You might consider installing a rope clutch above the genoa winch in order to free it up. A free winch can be handy for lots of things.
knothead is offline
post #86 of 106 Old 06-29-2008
Sea Slacker
I thought about it - but it would have to go below on my mast (lines go down, under the mast onto sheaves) and there isn't much space down there for various reasons. But I probably do need to revisit this. As it stands, I have to pull my topping lift by hand because it is on the same side as a genoa halyard.
brak is offline
post #87 of 106 Old 06-29-2008
A good feature with the ATN topclimber seems to be that it can get you to and over the very top of the mast, where a certain amount of maintenance is required. Somethin' i like with idea of the 6-part tackle is that its components, two triple blocks and a long 7/16" line, have value just as spare stuff for situations that might come up cruising.
sapo is offline
post #88 of 106 Old 07-02-2008
going up the mast, safety, etc.
Being a scrawny, mechanically and electrically savvy person has raised me to new heights on more than one occasion. Couldn't resist the Bob Hope joke...
Now, the serious business of going up and down a mast in safety:
The first thing you need to do is make sure that the halyard you'll be raised on is in good shape. Sounds simplistic, but when it's your own precious hide hanging from thirty to a hundred and thirty feet up, I'll take simple. Look at the line for fraying, cuts, etc., with a pair of binoculars. If the boat has internal halyards, tie a messenger line on the chosen halyard and raise it to the masthead and check the 'tail' for cuts, abrasion, etc.
The boatswain's chair needs to be comfortable. If it isn't, you'll be squirming around looking for a soft spot. This is experience speaking. My current owner went to West Marine and bought their most expensive, top of the line, ad infinitum chair and let me tell you that after ten minutes in that thing, it was killing my legs. Don't be embarrassed. Pull the thing out of the package at the store and pull it on. Sit down on something and lift where you'll be lifted. If it pulls on your legs in the store, it'll be a hundred times worse when you're up at the top of the mast. While we're talking about the chair, it needs to have a strap that goes between your legs, so if you happen to get turned upside down, you don't necessarily fall out. Back in the bad old days when I raced the Transpac, the seat I had didn't have a strap, and I nearly fell out one dark night while I was retrieving the busted spinnaker halyard. Before I crawled back into bed that night, I put a piece of nylon webbing on the thing--hand sewn with whipping twine.
Next thing: the chair needs to have pockets to carry stuff like tools, bulbs, grease, and so forth. Having a pocket that is part of the chair's sides is worthless, because as soon as your weight is fully on the chair, the pocket is like the front pocket of your teenaged daughter's tightest jeans. Useless, to say the least. Barring having a pocket, you should carry a CLOTH bucket with your stuff in it.
Which brings me to the next thing. Tools need to be tied to you, the chair, or the bucket. Dropping a screwdriver, neednosed pliers or whatever can turn them into a lethal weapon at worst, or something that's going to put a ding in the boat at least. (Or your only set of electrical crimpers will put a ding in someone or the boat, then bounce overboard in deep water...Been there, done that, too.)
For stuff you can't tie on, make sure they're clean and not slimy with grease, oil, water or sweat if you possibly can. Sometimes that doesn't work out, so take two or three of these items up with you.
Carry a messenger line. A piece of cheap 1/4 inch line tied to the chair will allow you to raise up that tool you forgot, a cold drink if you're up there a while, or the camera to get the obligatory picture of your feet and the deck below. It's also useful to carry a digital camera up in the bucket. That way you can take pictures of what you find wrong, fittings, etc. You can, all joking aside, also get some marvelous pictures when you're up forty feet or more...
Now we're down to the important part. Take the chair and go to the mast. If your halyards have snap shackles on them, connect the shackle to the chair's lifting ring, then take that roll of electrician's tape that's in your bucket and tape the pull-pin on the shackle so you can't accidentally snag and pop the shackle open. If your halyards don't have shackles, tie a bowline and then tape the tail to the halyard. Yes, yes, I know. Bowlines don't come out...and if you believe that, I've got a nice lot for sale in Georgia that is only a little swampy. Six inches of electricians tape is cheap life insurance.
Wear sailing gloves. Period. You can grab a shroud and find a meathook, stick yourself with a screwdriver, etc. Once again, cheap insurance.
Have whoever is turning the winch take four turns around the drum. Make sure that the person who is tailing that winch has gloves on. If the line starts to slip, gloves will keep him (or her) from getting a bad rope burn.
You can help the winch operator by making sure you don't get hung up on anything as you're being pulled up. Make it a point to stop at the spreaders and look at them for wear, corrosion, breakage, and so on. It also gives the person on the winch a little break.
Once you arrive at the masthead, relax a moment. You'll be stressed a bit, even if you've been up and down as often as I have in forty-five years of sailing. Inspect the shroud fittings. Look for corrosion. Are the fittings turning gold? You might need to consider a professional look at them to make sure they aren't ready to fail. Look at the turning blocks for the halyards. Make sure the sheaves aren't hogged out on their axles. A little bit of spray lubricant can go a long way up there.
Check the attachment points for spinnaker halyards. Are the shackles in good condition, or nearly worn through? Is the bail or whatever in good condition? Is everything with a nut/bolt tight? How about that VHF antenna? Does it look okay, or is the PL-259 connector for the coax cable a nice shade of green or black? Is the coax itself okay? Tug on it a little. Not hard, just a little. If it feels secure, it probably is, but a coax that is corroded out will pull right out of the connector with almost no effort. If it's bad, you can get a gold plated one at Radio Shack or West Marine. The gold plated ones last much longer and are not prone to corrosion like the cheapies that come with most antennas.
Now you're ready to work on the lights. Oops. You can't reach them sitting in the boatswain's chair. What to do?
This is where you have to raise a second halyard with a couple of loops firmly attached so you can stand up in the loops. If you think you're going to have to do this, try it about a foot off the deck first. Don't be forty or fifty feet up to try something new. This has a second problem. You'll need to be able to do the entire job with only one hand, because you'll be holding on to the mast with the other hand. For myself, I made my own boatswain's chair and it fits my scrawny self very closely. The attachment point is very close to the seat bottom. The only catch with this is that your center of mass is above the point you're attached, so going over backward is a very real possibility. But the bottom line is, with my own rig, I can be raise up high enough to be able to get my hands on most of the lights I've seen mounted on the masthead, the spar-fly, and all of those other goodies that are mounted on top of the mast without having to try and stand up and do the job with one hand.
Anyway, you don't want to spend a lifetime going up and down, so take a little time while you are there and fix things right. Clean the contacts on the lights if you have to take them apart. Change the lens if it needs it. Smear some silicone dielectric grease on things to keep moisture out and away from the electrical contacts.
Finally, test things before you come down. Nothing is quite so irritating as changing out the tri-color light's bulb only to find out it wasn't the bulb but the socket or wiring that was bad. Once again, been there, done that.
Take a last hard look around to make sure you didn't miss something. Take a hard look at where the halyards go over their turning blocks when the sails are down and the halyards are dock-secured.
Okay, it's time to come down. That's accomplished by the person who is tailing the winch. Have them put one hand over the line that's wrapped around the winch while they hold the tail in the other hand. When they allow the tail to approach the winch, you should start down. Four turns around the winch, however, may be too much friction, so they'll have to take off one or maybe even two wraps. That's where the hand around the winch comes in. A firm grip on the line that is wrapped around the winch is all it should take to hold you in place while they VERY CAREFULLY take a turn off the drum. After taking a turn off (3 turns left now) I would expect you to start down when they loosen the line. By keeping the hand around the drum, if they should lose the tail in the other hand, all they have to do to stop you is squeeze hard. It's not rocket science. It just takes focus and attention to detail.
The tailer should make his or her motions smoothly because up in the chair, a jerky motion at the winch is amplified. Someone who is experienced can let you down in one long smooth motion. I prefer to have beginners keep a good hold on the tail and only let me down an arm length at a time.
I know I've been long winded, but I've spent a lot of time in boatswain's chairs. Twice on the Transpac race, once on a LA to Tahiti run, and more times than I care to remember tied up in a marina or at anchor someplace. I even got the ride of my life down in Fort Lauderdale a few years back when one of the superboats had a little messenger line come untied from the company's logo flag, and that flag was flogging the next boat's mast and rigging. All of the 'guy crew' was ashore except the captain. I offered to go up the mast to retrieve the flag for him and he gladly accepted. The mast on that boat was about 120 feet from the water, and I had to go to the masthead to unjam the halyard so we could get the flag down. The view was, to say the least, spectacular. I've also gone up the mast of a Cal 47 while racing, and we never stopped racing. That is a little more spooky, because you look down and there's nothing down there but water.
In any event, I've survived all of these trips because I pay close attention while I'm standing on the deck, and I make sure that whoever is tailing the winch has their act together.
I hope this has helped. Good luck and don't forget the silicone grease...
Cap'n Gary
Gary1 is offline
post #89 of 106 Old 07-03-2008
Gary-
You should never use a shackle to connect the Bosun's chair to the halyard. You really should use a bowline or other knot. You really don't know if the splice that is holding the shackle is going to bear your weight—so even if you tape the shackle closed, you could still end up falling. If you're tied to the rope and know how to tie a proper bowline... there's no question about whether it will hold.
sailingdog is offline
post #90 of 106 Old 07-03-2008
Special Delivery
speciald's Avatar
Send a message via Skype™ to speciald
Read a story once of an unfortunate crewman on a megayacht. As usual, the smallest crewman was sent up. The crew started to pull him up the mast with an electric winch. Unfortunately as he got higher up the very tall mast, the weight of the halyard on the down side exceeded his weight and he headed for the masthead at an ever accelerating rate. I think he survived the sudden stop at the top. From then on they used a second line to hold him down .
speciald is offline
Southern Cross 31? db27513 Boat Review and Purchase Forum 36 09-02-2016 12:48 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 08:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 01:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 06:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 07:08 PM
