Old 05-16-2008
Joesaila's Avatar
1977 Morgan OI 30
Joesaila is on a distinguished road
Going Up the mast
OK, I've got it figured out. I have a good bosun's seat. I have to check some wire connections and change a couple of bulbs to LEDs. So that means two trips. I have a safety belt, I'm using both halyards and 2 winches. I will likely have two friends cranking away. My $1,000,000 question....How do I get safely lowered down? The winches only turn one way?? I can shinny and this is probably a dumb question...I'd really like the 'standard of care' answer.
I did see that post where Pigslo suggested paying a rigger $50...thats still an option.
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Old 05-16-2008
Zanshin's Avatar
Zanshin is on a distinguished road
http://www.sailnet.com/forums/gear-m...es-safely.html
Old 05-16-2008
Joe-
You shouldn't need two friends cranking away on winches... the safety line most people use is a fixed halyard, that is fastened near the base of the mast. You put a line ascender on it and then clip your harness to the line ascender. The line ascender comes up with you as you climb, and you lower it as you get lowered.
Yes, winches only turn one way, but if you take the line out of the self-tailer, you can ease the line down, using the wraps of line around the drum as a friction brake/clutch. By controlling the pressure on the tail of the line, you can ease the line and fat captain down fairly easily... much in the same way you'd ease a genoa line when the sail trim needs to be let out. See this sailnet article. (I think this is the same article as Zanshin had but with a fixed link)
BTW, I highly recommend you get used to doing it yourself... when your 20 +miles out...there usually isn't a rigger handy to pay.
This is a line ascender, which you can buy at REI or any good outdoor recreation store, and basically the same as the one I use. It is very similar in operation to a line stopper or cam clutch.
Old 05-16-2008
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Tell your winch man to slip the line slowly and continuously. A lot start by letting it out in jerks, which gets quite bouncy for the guy in the chair.
Jonathan-Livingston
Old 05-16-2008
If you've got two people on deck, have the other one hold the line in a waist-belay, so that if the first person screws up, you won't end up as a deck splat. It is so hard to get blood stains out of gelcoat, unless you've waxed it properly first.
Old 05-16-2008
ASA and PSIA Instructor
Joe-
....This is a line ascender, which you can buy at REI or any good outdoor recreation store, and basically the same as the one I use. It is very similar in operation to a line stopper or cam clutch.
SD,
I'm glad you let us know you have one of these devices...should I have a need up the mast I now know I can call you to come over and demonstrate how to use it properly.
PS. FWIW, I use a car battery pak to test all my lights just before the mast goes up, I wouldn't want SD to have to go up the mast on a lark.
Old 05-16-2008
SF-
You're cheating...testing the lights before putting up the mast... You big chicken...
Old 05-16-2008
Starter Pak
SF-
Yanno several years ago my wife bought one of these paks and put it in the trunk of her car. I complained at the time that it was a needless expense...of course since then it has started her, mine and several other cars a dozen times, usually in the nastiest of winter cold. She complains when it disappears to the boat for a week or two, as I use it to test the mast light circuits, and keep it aboard for the critical first start (just in case) as the boat floats off the trailer.
I guess I need to buy my own. So much for being a know-it-all.
Old 05-16-2008
sailortjk1's Avatar
Gravity usually works best for lowering someone down from a high place.
Courtney is My Hero
Old 05-16-2008
Gravity can be very, very unkind to people coming down from a high place...
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
Southern Cross 31? db27513 Boat Review and Purchase Forum 35 09-24-2007 10:58 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
