Old 05-16-2008
duffer1960's Avatar
Catalina 38 Avantura
duffer1960 is on a distinguished road
What Sandpaper grit for new bottom paint prep
I want to repaint my hull before the start of this season using the same paint I used the previous seasons (I have a couple of gallons extra). Anyway, the existing, and new, paint is an epoxy based paint (read NON-ablative). I only want to scuff the existing paint to get good adherance with the new paint. I DO NOT, I repeat, DO NOT want to remove the existing paint. Therefore what is the best grit to use? I am used to automotive refinishing where the final prep is with 320 grit paper, but I know that is too fine for this case. Is 150 the answer? I know 50 and 80 would be too coarse because that is what I used a few years ago to remove the previous coating of ablative. Thanks.
Sincerely,
Russ Duff
Catalina 38, Hull #112
"AVANTURA"
Lake Erie
Grosse Ile, Michigan
Old 05-16-2008
150 might be a bit fine... I've used a 120 grit with good results. Don't forget to wear a good full-face respirator with a dust filter in it, as the dust from sanding bottom paint is a heavy metal toxin.
Old 05-16-2008
LarryandSusanMacDonald's Avatar
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald will become famous soon enough
I'd get a piece of 120, 150, & 180 and try it - starting with the 180. Wear a mask. A tyvek suit would be good, too. And gloves. You're probably right, though 150 should be close.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
Old 05-16-2008
BarryL's Avatar
BarryL is on a distinguished road
Hello,
What does the paint vendor recommend? When I was applying new bottom paint on my boat, Pettit, the manufacturer, recommended using 80 grit.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 05-16-2008
ASA and PSIA Instructor
For most paints I'd use 80 grit, see the thread http://www.sailnet.com/forums/gear-m...iler-boat.html and call the US Paint 800 number if your situation is not otherwise addressed.
Old 05-16-2008
christyleigh's Avatar
christyleigh is on a distinguished road
I've always used 60 or 80 on a 5" or 6" random orbital with a vacuum attached for my yearly or bi-yearly scuff before painting. Anything over 100 and you'll need a hundred discs to do your 38 footer as it will fill up in no time at all.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Questions: Bottom paint prep work for trailer boat venturousviking Gear & Maintenance 22 04-23-2008 10:48 AM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
