Old 05-16-2008
EO32's Avatar
EO32 is on a distinguished road
What is the cloth inside my mast?
I'm putting some air horns on my mast and I'm trying to run the air tube down the center. It seems to be lined with a cloth, I suspect to keep noise down from internal wires banging along the sides.
Is this common?
There seems to be a wad of it at the base, which is making my hose run difficult.
BTW: I'm no longer a "Up the Mast" virgin.
Old 05-16-2008
Umm... do you have photos of the cloth or the air horns???
Old 05-16-2008
TrueBlue's Avatar
Seńor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Never heard of rags inside a mast - they're supposed to be on the outside (g). Did a PO stuff some rags up the mast in an attempt to isolate wire banging? Is it deck stepped?
True Blue . . .
sold the Nauticat
Old 05-16-2008
EO32's Avatar
The cloth runs the entire length of the mast, like a liner. I'm using a borescope to look at it. It's a keel stepped mast. I doubt the PO added it.
Old 05-16-2008
Hmm. that sounds odd... since a cloth would absorb and hold seawater, and probably increase the chances of corrosion problems.
Old 05-16-2008
EO32's Avatar
Maybe cloth is the wrong word. It kind of has the texture of lightweight fiberglass mat. It might be a plastic. I'm going to try to pull some of it out through my 1/2 inch hole at the base.
Old 05-16-2008
Wannafish is on a distinguished road
"I'm going to try to pull some of it out through my 1/2 inch hole at the base."
Ewww. That sounds painful!
Old 05-16-2008
FarCry's Avatar
Bombay Clipper
FarCry is on a distinguished road
Probably less painful than leaving it there.
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
Southern Cross 31? db27513 Boat Review and Purchase Forum 35 09-24-2007 10:58 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
