Blogs
User Name
  #21 (permalink)
Old 05-20-2008
bubb2 bubb2 is online now
bubb2 will become famous soon enoughbubb2 will become famous soon enough
Bubb2-
The stackpack is a great idea, but a StackPack is a Doyle sail loft creation and is attached to the sail.... a better idea is to get a StackPack like sail cover that uses the sail track on the boom instead. Gui's boat has one.
Dog, sorry I used stack pack like I use band-aid. I have one on my boat also, not a Doyle. The sail cover slides in to the track on top of the boom and bolt rope on the foot of the main then also sides in after the sail cover is in place. For winter storage I take the boom off completely. Come spring I reattach the boom at the goose neck and the ridged Vang then run my jiffy reefing lines and I am done, 45 min if I stop for a beer.
  #22 (permalink)
Old 05-20-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Bubb2-
I don't understand why Doyle has to attach their StackPack to the damn sail. There really isn't any need for that if you have a loose-footed mainsail, which is pretty much the case for most modern sails.
How are the girls doing... still staying out later than you'd like? OF course to you, they'll always be six years old... I think that's true of all parents.
If you're new to the Sailnet Forums... please read this POST.
  #23 (permalink)
Old 07-16-2008
BlueBustard's Avatar
BlueBustard BlueBustard is offline
BlueBustard is on a distinguished road
The best I've seen (so far) are E-Z-Jax (ezjaxdotcom.) Their advantage is that they are immediately stowable alongside the mast and boom while under sail. When needed, they can be swiftly deployed.
By doing some math and some advanced head-scratching, you could copy their design for your own personal use. But why bother when their cost is so reasonable?
Sponsored Ad
  #24 (permalink)
Old 07-16-2008
Blue-
The home made lazy jack system on my boat can what the EZJax can, and were probably a lot cheaper to make. Will be leading the system back to the cockpit later this summer.
  #25 (permalink)
Old 07-16-2008
teshannon's Avatar
teshannon teshannon is offline
teshannon has a spectacular aura aboutteshannon has a spectacular aura aboutteshannon has a spectacular aura about
SD,
Why are you leading it back to the cockpit? I usually don't touch mine. They are slack enough not to interfere with the main (other than a batten hanging up once in a while when raising the main) and still tight enough to be effective.
  #26 (permalink)
Old 07-16-2008
r2k815 r2k815 is offline
r2k815 is on a distinguished road
Can a lazy jack system also function as a boom topping lift? My San Juan still has the pig tail hook on the backstay, so this seems like a significant improvement.
Thanks
  #27 (permalink)
Old 07-16-2008
I like the idea of slacking them off completely when sailing.
Originally Posted by teshannon View Post
SD,
  #28 (permalink)
Old 07-16-2008
EO32's Avatar
EO32 EO32 is offline
EO32 is on a distinguished road
My homemade ones lift from the center of the spreaders and have some shock cord in them, so other than getting a batten caught while raising, they barely rest against the sail.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Display Modes
vB code is On
Steering System Spring Checkup Tom Wood Gear and Maintenance Articles 0 04-26-2004 09:00 PM
Ted Herman Lazy Jack duffer1960 General Discussion (sailing related) 0 11-02-2001 08:45 AM
Communications Made Easy Paul & Sheryl Shard Seamanship Articles 0 09-22-2001 09:00 PM
Communications Made Easy Paul & Sheryl Shard Gear and Maintenance Articles 0 09-22-2001 09:00 PM
Lazy-Jack or Dutchman System Dan Dickison Gear and Maintenance Articles 0 01-17-2001 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
