Blogs
User Name
  #11 (permalink)
Old 05-18-2008
knothead's Avatar
knothead knothead is offline
Rigger
knothead will become famous soon enoughknothead will become famous soon enough
Originally Posted by halekai36 View Post
Or on a PC using the free, much safer and option loaded MOZILLA FIREFOX! Why anyone would still use Internet Explorer is beyond comprehension for me....
That is the case. Sorry, I thought that they all did that.
I was convinced to use Firefox when I had to have my computer reformatted because of using IE.
Steve
SSMR Inc.
"wikijar"
  #12 (permalink)
Old 05-18-2008
camaraderie's Avatar
camaraderie camaraderie is online now
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Greg...hard to tell from the pix, but do you see any RUST at the hull/keel joint or on any of those bulges?
If you do...the only place it could be coming from is the embedded keel bolts which could have rusted out with water intrusion over the years. The bolt you can see in the bilge may look great on top and be nothing but rust below. Since steel expands as it rusts...that could explain the bulges. Solution would involve dropping the keel and a lot of work.
If no rust is seen, I'd just fair the keel/hull joint, and keel surface....slap on a few coats of epoxy barrier coat, then some bottom paint and go sailing.
Tayana 52 Ketch
  #13 (permalink)
Old 05-18-2008
seafarerGreg seafarerGreg is offline
seafarerGreg is on a distinguished road
update...
G'day,
Well i was outside today and started to dig at the bulges, and got the grinder out as well. Turns out what the problem is (my best guess) is there are pockets of casting sand all along this one level of the keel. It must have been from where they stopped the first pour of lead in the mold and installed the keel bolts. Then finished pouring and some sand must have fallen in. it doesn't go in very deep.. about 1/2 to 3/4 of an inch.
flickr.com/photos/23971349@N05/
I added a couple more pictures of where i have taken the drill and dug out as much of the sand as possible, and i will finish with the grinder when it stops raining.
in one of th new pictures you can see all the red sand everywheres....
Water must have gotten into the sand pockets and swelled.... or froze.
i will keep you updated as i go.
Does anyone know how long roughly the threaded rod for the keel tends to be?
thanks,
-Greg
Display Modes
vB code is On
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 15 03-20-2008 04:36 PM
Best type of keel halsmithjr Seamanship 10 07-01-2006 12:18 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Winged Keels Pros & Cons OldGlory Buying a Boat 13 04-09-2002 05:51 PM
The Dreaded Keel Bolt Leak Mark Matthews Gear and Maintenance Articles 0 04-07-2002 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
