Ok, so first chainplate rebedding project - as always from a small issue arises a giant repair
This is what chainplates used to look like:
I disconnected shrouds one at a time, and removed the plate. I will spare everyone the sight of what was under these plates - suffice to say it was a mix of a few different sealants and unknown compounds.
After 2 hours of chiseling, digging, filing, polishing and cleaning, here is how chainplates go through the deck:
Rebedding with Sika 521UV was easy (and it even worked in the rain, which is good because otherwise I would have to stop working and finish next week). Here is an almost-complete chainplate (got to clean off a few streaks, Sika 521 cleans up nicely with dry paper towel)
That white residue a little away from the plate is remainder of really really old polyurethane (5200?). It's as hard as rock - will never come off. Please people, don't use 5200 for sealing or bedding, for the sake of a next owner of your boat!!!
Now, here is what the chainplate looks like from inside.
Chainplates were originally painted with what appears to be
epoxy (same
epoxy based
paint that all the inside boat surfaces are painted with).
As clearly can be seen, it peeled in a few places where water intrusion used to be, presumably. However, outside those areas it is pretty well stuck to chainplates and virtually impossible to remove even with a chisel. Interestingly enough (and apparently against the theory that stainless needs to be exposed to air) in places where
epoxy was well stuck to the chainplate, and I was able to break off a piece, metal surface is nice and shiny. Most superficial rust is found where
paint was loose but not quite came off - perhaps trapping water underneath? Anyway, they clean up really nicely with a copper brush, but since I can't remove most of the
epoxy paint, I didn't try to clean them too much - they would never look nice and uniform anyway.
And here is how chainplates are bolted to the bases:
Note how deeply the nuts are embedded - they are essentially inside fiberglass surface (that covers plywood base) and painted with the same
epoxy compound. Dremeling them out would significantly damage chainplate base.
And here is what can happen to a brand new part. This is the same broken fork that I posted a picture of previously. I took a somewhat higher resolution photo today (I really need a camera with better close-up mode).
Looks like swiss cheese
