Old 05-18-2008
J36ZT is on a distinguished road
Mast Bedding Compound
Although I've been reading the posts for many months now, this is my first posting...so please forgive me if/when I screw things up.
Here is the situation: I have an aluminum mast that needs all the hardware put back on it following painting. Most of the fasteners are stainless steel. I will use aluminum rivets whereever possible, but there'll still be many screws.
The question: What is the best bedding compound to use for the stainless fasteners and what is best for the aluminum rivets?
PS Yes, this is for a J/36 if that makes much of a difference.
PPS I welcome any added advise on restoring the mast as well.
Old 05-18-2008
steelboat is on a distinguished road
Tefgel. It's all most riggers use. Insulate with pieces of light plastic (even a cut up milk carton will do) and use tefgel on all the screws.
Best, Bob S/V Restless
Old 05-18-2008
I'd second what Steelboat said, and add the following:
If you can't find or get TefGel, you can use Lanocote on the rivets and LocTite on the screws.
BTW, I would highly recommend using STAINLESS STEEL or MONEL rivets, rather than aluminum ones. They're a lot stronger and much more fatigue and corrosion resistant.
Old 05-18-2008
knothead's Avatar
I have been using a product called Tuff-Gel lately, It's made by the same company that makes Tef-Gel. It seems to be very similar but has a thread locking component in addition to the Teflon.
Ron Paul 2012
"wikijar"
Old 05-19-2008
knothead's Avatar
This is one of the few areas that I disagree with SD.
This is just my opinion.
In general, if you are attaching a stainless piece to a spar. Then use stainless rivets. If you are attaching a aluminum piece. Use aluminum rivets.
If you are installing a plastic conduit inside the spar. Use aluminum rivets.
There are some exceptions but I have never seen any point in introducing dissimilar metals where it's not needed.
If strength is a factor then you may need to use SS or Monel.
I know that if properly coated with a insulating compound you can reduce or perhaps even eliminate electrolysis for awhile. But you will definitely have more of an issue with dissimilar metals.
Ron Paul 2012
"wikijar"
Old 05-19-2008
Knothead-
I'd agree that avoiding dissimilar metals whenever possible is a good idea. Plastic washers and tefgel/lanocote help with galvanic corrosion issues, but sometimes, using dissimilar metals is really the right way to go.
Old 05-19-2008
knothead's Avatar
Knothead-
Agreed. Just wanted to say that sometimes aluminum rivets are the way to go.
Ron Paul 2012
"wikijar"
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
Southern Cross 31? db27513 Boat Review and Purchase Forum 35 09-24-2007 10:58 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
