Blogs
User Name
Old 05-18-2008
jonb jonb is offline
jonb is on a distinguished road
Rudder Bearing Replacement - C&C 44
I just brought my boat from it's previous owners port of Sarnia, Ontario at the south end of Lake Huron to Kingston, Ontario at the east end of Lake Ontario.
The boat is a 1986 C&C 44.
The boat surveyed fine and when on the hard over the winter there was no play in the rudder at all.
Over the course of our 5 day journey we started to get rudder movement at high engine rpms and then significant rudder movement while sailing.
The rudder shaft enters the hull and is contained in a tube that is approx 18 inch high. This tube is secured to the hull with substantial reinforcment.
In the tube there is a grease fitting. I assume there is a bearing below and a bearing above the grease fitting.
The rudder post exits the tube above this section for about 18 inches at which point the quadrant is attached and then the rudder post enters a receptacle below the helm seat.
While watching the rudder post work while under sail, the receptacle under the helm seat was bending significantly and the rudder shaft was grinding and squeaking.
Can anyone help with what bearings were used by C&C on their larger boats in the mid 1980's. I have numerous questions.
How many bearings are there? What are they made from?
Where can they be obtained from? What is the procedure to replace the bearings?
I assume it means hauling the boat despite the fact that the top of the rudder is above the water line.
Is it reasonable for bearings to degrade over a 400 mile/5 day period?
They seem to have gone from no play at all to totally worn out very rapidly.
After seeing the rudder post work in far from difficult conditions I feel the need to address the problem immediately.
Any information on this topic would help considerably.
C&C 44
Kingston/Lake Ontario
Old 05-19-2008
Is there anyone who has had a similar problem with one of the older C&C's.
Any help would be much appreciated.
I am trying to determine next steps.
C&C 44
Old 05-19-2008
Paul_L Paul_L is offline
Paul_L is on a distinguished road
This is not directly C&C related, but here are some links showing rudder bearing replacements on J's:
Eos Rudder Bearing Replacement
J40 Rudder Bearings
PauL L
Old 05-19-2008
Paul, Thanks for the link.
I believe some C&C's (possibly all) use a plastic bushing system instead of bearings but I really have little information to confirm this.
It is surprising how the J boats have had many problems with the Harken bearings.
C&C 44
Display Modes
vB code is On
Rudder bearing replacement - Irwin 37CC jwsbrae Gear & Maintenance 1 02-09-2008 12:19 PM
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 3 02-02-2007 06:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
