I just replaced my filter in the same Racor model yesterday.
It is as easy as it gets.
1) Using the T-handle on top unscrew the cap
2) Using plastic handles on the filter body (they lift from it's top on older models or just around the sides on newer ones) lift it (you may need to turn it counter-clockwise as you lift). Filter sits on the tube that goes through its center vertically.
3) Install new filter just the same (on the tube, while rotating).
4) Optionally replace the gasket that sits inside the grove of the filter cover (they supply this gasket with each replacement filter but they seem to last a lot longer than filters for me).
5) To avoid re-priming your engine, have some clean diesel available and refill the filter to the top before replacing the cover. My engine just starts right up after that, may be coughs a bit for the first few seconds and that's it - no priming needed.
You can also drain the separated water and all sorts of gunk from filter bottom by opening the plug on the bottom some - don't forget to have a pan or another container underneath.
If your fuel is dirty like mine, there will be a lot of "coffe grind" coming out but some of the sediment stays inside the filter bowl. I haven't found a good way to get it out of there (flushing with diesel does not help) - would welcome ideas
