05-19-2008
An unvented heater is often a serious CO poisoning risk, even if you vent the cabin. Often venting the cabin lets out just as much heat as the heater creates, so the net gain is minimal. If you are going to do this, make sure you have installed a working CO detector. CO poisoning is very subtle and can kill you.
As for running a heater and having a battery nearby...not a problem unless you're charging said battery. Lead-acid batteries do not outgas hydrogen as a general rule unless they are being charged or were recently charged.
I’m really concerned with the first question. The boat is a 1976 Mirage 24 which is basically a C&C 25 minus a foot. It has one house battery, which is stored under the port side lazerette. To keep the cabin warm this weekend, I wanted to use one of those Lil Buddy propane heaters. With the hatch cracked open it’s safe in terms of carbon monoxide but my concern is what about fumes from the battery?
Is it unsafe to run a propane heater with a battery in the same cabin? I’m thinking it should be okay, people cook in galleys on weekend cruisers that have several batteries inside the cabin but I’d like to see what those with more knowledge have to say.
