Old 05-19-2008
gwp gwp is offline
gwp is on a distinguished road
Yanmar Oil Pressure Light/Alarm Out? Please help!
1986 2GM20F
Can someone give me some ideas as to why, all of a sudden, when I turn the key to the "on" position, the oil pressure alarm doesn't sound nor the light come on? I'm pretty sure the sending unit is designed as normally closed, and it is grounded properly. When I throw the test switch, the alarm sounds and the "charge" light comes on. Trying to help a friend. Any help very much appreciated!
Old 05-19-2008
badsanta is on a distinguished road
if it worked before and now not. I would check the fuses and ground. There may be some inline fuses buried in the wiring harness next to the engine
Yanmar oil pressure brak Gear & Maintenance 4 05-04-2008 09:40 PM
Oil Pressure Mystery Solved bsfree Gear & Maintenance 5 12-21-2007 07:23 PM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 09:45 AM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
Oil Pressure Problems Tom Wood Gear and Maintenance Articles 0 05-16-2002 08:00 PM
