05-20-2008
Originally Posted by JewelledJester
I have a merc 9.9 outboard that won't stay running without hitting the primer button on the carb. Has fresh gas and new plugs. Possible debris in carb? Any help would be nice, want to put in saturday.
I found on mine that idling when it hasn't been run for a long time it would do the same (it was brand new btw). I ended up keeping in neutral and increasing throttle up halfway between idle and full boar, let it run like that for three to five minutes (primer turned off), then bring it back down into idle worked well.
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
