05-20-2008
Originally Posted by Rockter
Roc...
If the gap between the surfaces needs to be oil-tight, do not, do not, do not lever them apart with a screwdriver!!!
It will leak afterwards.
Try a mallet, then (judiciously), a hammer.
Actually, that's incorrect. Where the bell housing mates up to the engine it is NOT oil tight.
The bell housing actually has a weep hole at bottom dead center to allow any leaking of the transmission input seal or the engines rear main seal to drip out of the bell housing indicating a problem. This is the area on an automobile where the clutch is, on a standard transmission, and as such you DO NOT want any leaking oil from a rear main seal getting on clutch plates so they design them with a weep hole.
That being said, a screw driver will only tend to throw the housing off center and the splines of the tranny and engine will bind and it won't go anywhere. It needs to be pulled straight off the engine! Use a wooden or rubber dead blow mallet and tap around the transmission output flange evenly. This will break the rust bond around the perimeter then slide it straight off.
What ever you do be VERY, VERY careful using penetrating oils in this area! PB Blaster, and the others, will EAT a rear main engine seal or a tranny seal in about 10 minutes flat and it will permanently be destroyed!!
______
-Maine Sail / CS-36T
