05-20-2008
I would guess that their 25-series boom vang, with a SWL of 1000 lbs. is probably what you would need.
You should call them, and ask them... they'll be able to tell you what would work for your boat.
Garhauer is now stock gear for several manufacturers, including Catalina, and Catalina has a boat about the same size as yours—the Catalina 25 appears to use a 25-series boom vang, as you can see here.
