05-30-2008
moderate?
Originally Posted by NautiG
I just bought a delta like Sailhog's. Any advice on methods of deployment and retrieval, as it would differ from the danforths I'm accustomed to? The literature describes the delta as "self-launching", whatever that means. Also, there are two eyelets on the shank. One at the end and one towards the plow-head. How is this second eyelet meant to be used?
Currently, retrieving an anchor without a windlass, I pull in the rode until the boat is directly above the anchor. Then I tie off the chain and put the engine in forward until the anchor breaks loose from the bottom.
Scott
Gemini Catamaran Split Decision
Captain's Blog
The hole at the plow head can be used to rig an anchor trip line, or shackle another anchor in tandem as Giu does, or to run a pin through on your bow roller (as I do) so the anchor won't come loose and self deploy in rough conditions.
Self launching means that in a bow roller...once you release the anchor chain or rode, the weight of the plow head will cause the anchor to drop by itself.
My own technique with the Delta is to let the head hit the bottome then slowly pay out the rode as the current or wind pushes you back. At about 1/3 of the intended rode, take a quick snub around a cleat to make the anchor bite...you will feel it do so. Then let out the rest of the rode intended and watch for a bit to insure you are not dragging. Some like to set with the engine. I find this tends to pull the anchor out in softer bottoms and prefer to let the wind and tides do the work.
