Bleeding your Yanmar Engine - Page 3 - SailNet Community
Blogs
  #21 (permalink)
Old 07-28-2008
beej67's Avatar
beej67 is on a distinguished road
I don't bleed my lines when I change fuel filters, (Yanmare 3GM) and have never had a problem.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
  #22 (permalink)
Old 07-30-2008
LittleWingCA is on a distinguished road
On my Yanmar 2QM15 engine the return fuel line doesn't run to the fuel tank, but to another input connection to the Yanmar's local fuel filter housing assembly. When I had a mechanic service the engine after buying my boat, he bled the fuel system by simply using a hand held pump like he used to extract the dirty oil, and connected it to the end of the return hose. As he applied suction, the fuel was pulled from the tank, through the fuel line, through the new Racor assembly, through more fuel line, through the Yanmar fuel piping system and out the return line. Once he saw some come out the return line, he just connected the hose back to the fuel filter assembly, tightened the hose clamp, and the engine fired right up on the first try.
LittleWingCA
1980 Pacific Seacraft Orion 27
Sailing Grounds: Southern California
  #23 (permalink)
Old 08-14-2008
SailorByFate is on a distinguished road
The lift pump sounds like a good idea. Which Facet model would be the right size for a 20HP 3GM(D)? I noticed Jody installed it after the Racor. Is there a reason not to install it before the Racor?
  #24 (permalink)
Old 08-14-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Any
Any of the three models they sell will work - I opted for the largest for optional ability to do fuel polishing if the need arised. I install after the Racor because the racor is designed to be the primary fuel filter. The Facets do also have a fuel filter - but not nearly the capacity ( < 5% of the Racor) - so I suggest putting it afterwards...
-- Jody
S/V "
1983, Barberis Show 38! or
  #25 (permalink)
Old 08-16-2008
menado is on a distinguished road
I agree with a sqeeze bulb, I have it for 27 years on diesel fuel and it is still working.
  #26 (permalink)
Old 08-16-2008
HALCYON's Avatar
HALCYON is on a distinguished road
Great post. I have the squeeze bulb installed before the Racor, works great and for $13 what a value. Whether electric pump or squeeze bulb, they both make bleeding so much easier than the little manual actuatuion of the Yanmar lift pump.
Jim Woods
Halcyon 1986 P33-2 #31
  #27 (permalink)
Old 08-16-2008
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
JIM-- I keep meaning to do this because of your prior recommendations. This will go on the winter project list. Thanks!
Mitch
P-33-2 #146
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
  #28 (permalink)
Old 08-17-2009
Skipper995's Avatar
Skipper995 is on a distinguished road
The pictures were a great asset to the description. However there is one small error. The last picture posted is labeled with "hi" and "low" side backward on the injectors. The fuel lines entering the side of the injectors are the "high side" (17mm) and the banjo bolt (14mm) on the top of the injectors are the "low side" return.
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 09:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 09:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 08:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
