Bleeding your Yanmar Engine - Page 4 - SailNet Community
 5Likes
post #31 of 42 Old 03-22-2012
beej67's Avatar
Re: Bleeding your Yanmar Engine
Originally Posted by beej67 View Post
I don't bleed my lines when I change fuel filters, (Yanmare 3GM) and have never had a problem.
Well I had my first problem about a year ago. The little hand pump that's built into the Yanmar engine is pretty terrible too. I went to the marine store, bought one of those squeezy-bulbs the outboarders use, and spliced it in the line downstream of the fuel filter, but before the engine. Five or six good squeezes and I could hear fuel dropping back into the tank from the return lines, and the air was bled out. Piece of cake.
eckcn17 likes this.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
beej67 is offline
post #32 of 42 Old 03-22-2012
Thanks Beej, that makes a lot of sense.
harley2862 is offline
post #33 of 42 Old 11-09-2012
I believe your picture showing "fuel injector pump" is wrong.
That is the fuel filter assembly. It is not high pressure. High pressure starts @ the internal fuel injector pump.
The bleed valve attached to the high pressure pump is on the low pressure side.
sellongitab is offline
post #34 of 42 Old 12-31-2012
Sellongitab is correct in pointing out that the article and photos incorrectly identify low pressure bleed points as high pressure ones.
The fuel is pressurised by the high pressure pump after which the fuel lines are all metal pipes not rubber hose and there are no bleed nipples. If you need to bleed the high pressure side you need to crack open each injector feed pipe.
If this could be edited a good article would become even better and less likely to cause confusion to newcomers.
warrenden is offline
post #35 of 42 Old 03-13-2013
Thank you so much for that post. You saved a lot of heart ache! Much appreciated!
Puchalouver is offline
post #36 of 42 Old 05-27-2014
Hi great posting, very useful
My Yanmar 3JH3E is 40hp and has been a great work horse. Last season I replaced the primary and secondary filters and I have bled the system I think successfully after using your guidelines. However what I do find is that after running the engine in gear for 30 minutes or so, it tends to just drop power and then rev up again. Occasionally it does drop power and cut out completely, but most time it just looses revs then up again. I normally run the engine at 2500 revs, but this also happens when running at high revs of around 3500. This weekend the engine ran smoothly for 3 hours (no wind on the east coast of England) and then stopped... but each time it happens it starts quickly and off we go again.
Just wondered whether you had any idea, before I get the professionals in the look at it?
Many thanks
John
johnlbailey is offline
post #37 of 42 Old 06-20-2014
Wink Re: Tutorial: Bleeding your Yanmar Engine
Originally Posted by artbyjody View Post
Introduction and Disclaimer:
This is a picture tutorial of how to properly bleed your Yanmar Diesel engine. It will also cover other maintenance issues as well, and is provided with no warranties or thought of accuracy. Use this information at your own risk, and is merely provided to assist others that are like me, a bit mechanically challenged. A good portion of this tutorial is from knowledge gleamed from "You can call me David", and other forum members.
When do you need to bleed your Diesel?
1. When you change out any parts related to your fuel system. Such items may be, fuel lines, various fuel filters, mechanical pump, injector pump etc.
2. When you have run out of fuel and refill after such. Note: If you run out of fuel, you will positively realize the effects of algae and other sludge in your tank, keep an eye on your Rancor fuel filter, and I personally recommend when re-fueling after exhausting your tank - do it with the pump handle set at the slowest pump selection possible as not stir up residual sludge at the bottom of the tank.
3. Anytime that the engine appears to cut-out, as this may be an indication that there is a leak in your system that air can be introduced.
WARNING:
Anytime that your engine is not able to turn over after 2 or more tries, and if you have not done so - locate your water inlet valve for your Engines water intake and TURN IT OFF - until the engine is running. If you do not you RISK ruining your engine as it will be likely that you will siphon water into your engine and since water is not easily compressionable by your engine - you will blow out gaskets, ruin cylinders and if water sits in there - will rust out your engine quicker than you can say duh.
When starting the engine, it is important that the water shut off is done, but also do not try to start the engine for more than 2-5 seconds at a time, without allowing it (the starter) to cool down in between. Trying to make it start by holding the starting button for long periods of time will cause your starter to overheat, and you risk a possible explosion or start of a electrical fire. Patience is the virtue that must be practiced with this procedure.
Starting at the front of your Engine.
Attachment 1641
In the picture above, you will note one item that probably is not part of your normal Yanmar engine setup. That will be the Facet electric diesel fuel pump. This is a mod I added to the fuel system, to allow me to bleed the fuel lines without requiring me to run up to the cockpit to turn the engine over, or manually depress the mechanical lever on the Yanmar's fuel pump like a crazy man.
This particular pump is easy to install, and when not powered is passive, which means it can remain inline of the fuel line going to the engine as it will not restrict the flow of fuel once powered off. In the installation pictured, there is a push / pull switch that I installed into the bilge (not pictured) that allows for easy access for powering it on and off, when I am required to bleed the system or in the event that the mechanical fuel pump fails underway.
The part is $124 from Napa, and the push / pull switch is about $9. You may also need additional fuel line and adapter barbs if you locate the pump elsewhere. But for less than $170 bucks, less than an hour install time, a worthwhile mod to make to your system.
You will notice that the picture above, also denotes where your water intake valve is. On my vessel it is located forward of the engine. SHUT IT OFF and do not turn back on until engine is running.
I also annotated where the bleed valve for the Rancor is. Water is heavier than fuel so it is important to check the Rancor filter to make sure that the bottom of the clear portion of the filter is not filled with debris etc. To drain any water there is a little twisty at the bottom that you unscrew. Unscrew and keep a fuel/oil mat or rag underneath, and it will drain. When red dyed diesel comes out - screw back in.
At the top of the Rancor is a vent valve. I find with the electric pump installed there really is no need to open this, but officially, this is the first place to start.
Starboard side of the engine:
Attachment 1642
In the picture above, you will see that I have annotated fuel related components. Starting aft (the left in the photo), we see the Yanmar mechanical pump. This is the part I replaced because the outlet side was leaking and the outlet screw piece was stripped on the original part. The part is around $70-130 depending on your make and model of your diesel. MAKE SURE, you get a gasket with the new part as they do not come with one. The gasket is around $2, and you can not re-use the old one. If you simply bolt it on without one, you will find that your engine will run well once bled but will leak oil like a banshee into your bilge - and it won't be long before you get oil warning lights and alarms.
Forward in the photo (to the right) is the injector and it also has a small fuel filter as well, located at the bottom of the unit. If you are changing out your Rancor, this would be a good time to replace this one as well.
In the photo I have numbered the bleed points for quick visual identification.
NOTE: Place a fuel / oil absorption mat or rag under the areas as you bleed to catch fuel.
To pressurize the system, manually cycle the mechanical fuel pump lever up and down or turn on the electric pump (if you have installed one). Starting with #1 to #3, one at a time, crack them open using a crescent wrench of proper size. When I state crack, just enough to unseat the bolt. You will see air bubbles escape through the fuel. Keep cycling the fuel pump lever until nothing but fuel comes out. Once you have nothing but fuel coming out - tighten the bolt - be careful not to over tighten them as if you strip them, it means replacing the part.
#1 through #3 are part of your low pressure fuel system. If these are bled successfully, most of the air that you should be worried about will be in your HI pressure system, which I will cover next.
HI Pressure System.
In the same picture above, note where the HI Pressure relief valve is. WARNING - wear protective goggles and loosen slowly as fuel can spray when under pressure and cause injury.
Use a properly sized crescent wrench or flat head screw driver and crack this nut ever so slowly. You will get a bunch of air escaping and remember this is under pressure. Remember you have to manually depress the fuel lever to pump fuel or rely on the electrical diesel pump if you have installed one. Be patient as it will take some time. Use a large fuel / oil absorption mat under it as more fuel than not will come out with the air. When no more air is escaping re-tighten.
Attachment 1643
Next locate the other hi pressure relief point on the starboard side - forward of your engine. This one is illustrated in the photo above and will be on the top right of the photo. Using a phillips head screwdriver or crescent wrench - repeat the same process you did with the previous one.
Now, we need to move to the port side of the engine. Repeating the same processes as before, and release the air out of the fuel intake of the cylinders (again HI Pressure).
Attachment 1644
Locate the three HI Pressure nuts on the port side of the engine as per the above photo. Notice that I annotated the LO pressure side as well, you will most likely not need to touch these as they are fuel return and do not impact air in the fuel / starting or engine running problems. Repeat the same process we did on the previous ones, starting with the most forward one (#1) and working your way back to #3, ONE AT A TIME. Remember - this is the HI Pressure side and protective goggles are suggested.
Wahoo! Am I done now?
Maybe. Now is time to crank the engine. Keep the water intake valve SHUT for now. Try starting the engine.
1. It doesn't start after 2 tries.
Repeat the above process on the high pressure locations only. Start on the starboard side of the engine and work your way around. We may need to repeat this process several times as you will be surprised how much air is in the system.
2. It runs. Turn on the water intake valve now. Check to make sure your are getting water out of your exhaust. Now put your engine under load by putting your boat in forward or reverse and give it throttle. If you are tied up at the pier, prior to make sure your lines are properly properly secured. Run under load for 5 minutes or so.
If its hums along, you may be done, but if the engine sputters and dies out. Repeat the process again, shut off the water intake valve down below, and bleed the hi pressure locations described starting on the starboard side working around to port.
So, there you have it. A pictorial tutorial that should allow the true mechanic in you to come alive.
I hope you find this helpful and that the mysteries of "bleeding" a diesel are de-mystified. You should probably print this out and keep it on your boat in the event this happens while you are underway.
NOTE: I may have made some technical labeling errors in some areas, and will correct as needed, however - this document gives a very elementary overview of how to do the task.
Hi I realize this is an old post, but after reading it, felt compelled to write. Firstly, what you indicate firstly as an injection pump, and then secondly as an injector, is actually just a filter on the stbd side. Next you emphasize leaving the inlet water turned off until the engine is running?? You mentioin this to avoid syphoning. Any diesel engine mounted below the water line in a boat should have a loop installed (SW hose) between suction strainer and engine leading up above the level of the sea with an anti-syphon valve at the top.
This would eliminate any issues with syphoning and filling exhaust with SW. Also, as a mechanic, I would never advise the use of a crescent wrench in place of a properly fitting wrench of the correct size. My 2 cents.
Seidelmann is offline
post #38 of 42 Old 06-20-2014
Hi I realize this is an old post, but after reading it, felt compelled to write. Firstly, what you indicate firstly as an injection pump, and then secondly as an injector, is actually just a filter on the stbd side. Next you emphasize leaving the inlet water turned off until the engine is running?? You mentioin this to avoid syphoning. Any diesel engine mounted below the water line in a boat should have a loop installed leading up above the level of the sea with an anti-syphon valve at the top. Also, as a mechanic, I would never advise the use of a crescent wrench in place of a properly fitting wrench of the correct size. My 2 cents.
post #39 of 42 Old 06-20-2014
Old threads and anti syphon not withstanding , the raw water pump is easily capable of filling every thing if cranked with no start to blow it out the exhaust.That's why I like a drain valve in the aqua lift that automatically closes when oil pressure rises. It's also handy for winterizing and saving from rusting the exhaust valve while it waits for spring.
Capt Len is offline
post #40 of 42 Old 10-01-2015
Vere good instructions.
I have a Yanmar3gm30f and always bleed it at the Phillips screw.
Would it be better to bleed at the screw you recommend ?
carlager is offline
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
