Old 05-22-2008
Bristol
ardea is on a distinguished road
Garmin 478 chartplotter
I have recently purchase a Garmin 478 chartplotter and have been unsuccessful in downloading routes from my Offshore Navigator Light MapTech software on my computer to the chartplotter. Maptech does not have the driver software for this unit listed in their downloads. Has anyone found a way to download using Maptech.
Kurt Weinheimer
Old 05-22-2008
Connect the unit to the computer using the NMEA 0183 serial port, rather than the USB port. Maptech Offshore Navigator Light should have no problems with talking to the GPS then.
You will need the data cable as well as a serial port on your computer, and you'll need to make sure the Garmin is set to transmit in NMEA 0183 mode, which is 4800, 8, n, 1. The default is usually Garmin's proprietary serial protocol, which MapTech's software won't recognize.
Safe distance between compass and chartplotter tooslow Gear & Maintenance 4 03-01-2008 05:24 PM
Seeking Clarity on Garmin Chartplotters and Bluechart G2 Jim H Gear & Maintenance 3 02-03-2008 10:24 PM
Chartplotter Backlighting: Garmin vs. Raymarine labatt Gear & Maintenance 1 10-21-2007 10:12 PM
Deciphering what I need in a GPS chartplotter rryan14 Seamanship 18 03-13-2007 01:43 PM
Garmin Chartplotter Antenna? 1970Columbia34 Gear & Maintenance 10 02-22-2007 02:48 PM
