Pump Float and Three-Way Switch Install - Page 3 - SailNet Community
post #21 of 39 Old 05-23-2008
Max-
Depends on how deep the opening for the through hull is.
The formula for flooding is:
Q = 20 x d x square-root of h
Q = flooding rate in gpm
d = diameter of hole in inches
h = depth of hole underwater in feet
So, if your through-hull is 3' below the LWL, then you've got Q=20 x d (1) x h (sqrt 3) or 20 x 1 x 1.735 = 34.7 gpm.
A Rule 1500 pump supposedly does 1500 GPH, or 25 GPM. However, if the bilge pump hose has any head (vertical rise) that number drops significantly...so figure that a Rule 1500 would actually pump 15 GPM or so... You'd need a much bigger pump to keep your boat afloat.
sailingdog is offline
post #22 of 39 Old 05-23-2008 Thread Starter
1997 Dehler 33
max-on's Avatar
I have a manual pump to the cockpit, I do not know if it is high volume, by its size sitting on top of the keel in between the bolts, it probably is not. A second one is a good idea. I would need a third output line and another hole in the hull though?
max-on is offline
post #23 of 39 Old 05-23-2008 Thread Starter
1997 Dehler 33
max-on's Avatar
Max-
Saildrive leg, seacock 2 inches above the floor.
max-on is offline
post #24 of 39 Old 05-23-2008
Max-
What is the hull draft on your boat... how deep is that part of the hull???
post #25 of 39 Old 05-23-2008 Thread Starter
1997 Dehler 33
max-on's Avatar
I have not measured, but it is not much:
These pics are not great as they were taken with the blackberry, but they will give you an idea of the wetted surface.
Spec'd draft is 5.4.
max-on is offline
post #26 of 39 Old 05-23-2008
Seńor Member
TrueBlue's Avatar
I'll bet SD has the formula for calulating volume of a cylinder in s/f memorized . . . I'm too lazy to look it up.
But them again max, that boat is so flat it must plane!
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #27 of 39 Old 05-23-2008
christyleigh's Avatar
Originally Posted by TrueBlue View Post
Could not see any value in having an off position - especially in conjunction with a float or electronic sensor switch.
A hard wired 3 position is what I accustomed to on my last 3 boats. Lots of reasons for the OFF - Stuck float while sailing so pumping dry for X amount of time IF you can get down there and fix it right away or Not = burning out the pump, Cleaning or checking the float and bilge area. I like the Green to Red indicator on my NC but I had a Pumping indicator on my previous 2 boats. If I'm dumb enough to leave the boat without putting the switch on Auto - I deserve trouble.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #28 of 39 Old 05-23-2008
Max-
From those photos, I'd estimate, you're looking at 2' of head on the pump thruhull... so about 28 GPM.
TB-
FYI Volume of cylinder: Pi * R^2 *h
post #29 of 39 Old 05-24-2008
Owner, Green Bay Packers
Practical Boat Owner (UK) this month reviewed bilge pumps. They liked the Vetus EB80 and Plastimo 1400 in the large size pumps as well as the Atwood Tsunami; all did about 45 liters/min at 1 meter of head, with 12v input. The Tsunami was rated well also for efficiency, ie...water moved per amp. The Rule 27D was mid-pack to upper mid-pack ib flow rate, head and efficiency.
The most interesting pump they reviewed was the new Whale Supersub 500 which only pumped 35 liters/min rated and 15 liters/min at 1 meter head tested but it's compact size and ability tyo fit in a narrow or shallow bilge impressed. Most impressive was that it drew just over 1 amp versus 3 amps and higher for the other pumps tested. It pulls water down to 12 mm and it sounds like it would be an excellent housekeeping pump.
Note that the numbers cited in their tests were at 12 volts, admittedly a low voltage situation.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #30 of 39 Old 05-24-2008 Thread Starter
1997 Dehler 33
max-on's Avatar
Thanks Sailaway.
max-on is offline
