Pump Float and Three-Way Switch Install - Page 4 - SailNet Community
post #31 of 39 Old 05-24-2008
1987 Pearson 27
Joel73's Avatar
Max,
Looks like you're getting good info here. I will be posting photos of my bilge installation soon so maybe that will be of interest to you. As for the parts i used... we put in a Rule #41 3way panel switch with indicator light and built in fuse....
Also used a Rule 500GPH like this:
I would have put a larger pump in but we already had that one at the house for some reason so i decided that since it was paid for that i would get some use out of it. In the future i will probably upgrade to atleast the 750 if not the 1000.
For the plumbing.... i DID NOT want to add another through-hull so i just used a T connection into my manual line after the manual pump... Seems to work fine and back flow is not possible the way we installed it.
Anyway... i'll post about it soon.
"Unthinking respect for authority is the greatest enemy of truth." - Albert Einstein
Joel73 is offline
post #32 of 39 Old 05-25-2008 Thread Starter
1997 Dehler 33
max-on's Avatar
Joel, thanks for the reply and yes post some pics, I would like to see your setup and 'T' in the drain line. I am thinking it would be just as easy to keep the current pump wired to the breaker and install another pump connected to the battery with the sensor and the three-way switch. Should I get the switch with the fuse? What are the pros/cons of fuse/no fuse switch.
max-on is offline
post #33 of 39 Old 05-25-2008 Thread Starter
1997 Dehler 33
max-on's Avatar
SD, any comments on the switch, fuse/no fuse, and 'T' into the drain line?
max-on is offline
post #34 of 39 Old 05-26-2008
Well, having the fuse is a good idea, since the bilge pump switch is wired directly to the battery, rather than going through the DC panel if Joel did this right. There's no evidence to support this...
Switch is a good idea... not sure about the "T" into the drain line, since I've not seen the specifications on the other bilge pump or seen the layout of the through-hull it is attached to or the plumbing connecting everything.
sailingdog is offline
post #35 of 39 Old 05-26-2008 Thread Starter
1997 Dehler 33
max-on's Avatar
Thanks SD, so if I go directly to the battery and not the breaker as current, then get the switch like Joel and not the one I posted, unless I then add a fuse to the connection, which Joel's switch does automatically without the extra step. Thanks.
Yeah, I also would like to see how he did that drain line setup!
max-on is offline
post #36 of 39 Old 05-26-2008
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Max, going a little back, remember to size correctly your cables (based on the pump you choose), fuse it appropriatedely directly to the Batts, making soldering connections and good waterproofing. As saildog says, incorrect powering would also bring down your GPM capacity as well. In 2006 I replaced my floating switches by the electronic model. Well, now I'm back to the basic floating one, as those proved to be too sensitive and not reliable at all.
negrini is offline
post #37 of 39 Old 05-26-2008
DO NOT SOLDER CONNECTIONS ON A BOAT.
ABYC specification is for CRIMPED connections on a boat. It is far easier to make proper crimp connections, provided you have a good ratcheting crimping tool, than it is to properly solder a connection. Soldering also cause the marine grade wire to effectively turn into solid wire at the soldered joins, and creates a place where vibration will easily work harden and fatigue the wiring. It also can introduce a high-resistance spot in the case of a cold solder join, as well as galvanic corrosion issues, due to dissimilar metals being in close proximity.
The best connections are crimped with adhesive lined heatshrink tubing (or the heat shrink type crimp terminals) to seal the crimp from moisture.
post #38 of 39 Old 05-27-2008 Thread Starter
1997 Dehler 33
max-on's Avatar
Joel, any update?
max-on is offline
post #39 of 39 Old 05-27-2008
max-
He tested it, it didn't work and the boat sank with all hands aboard...
