05-24-2008
Originally Posted by Sapperwhite
the filter bleed nut bubbles after shut down, so thats an outie leak, found the low side of the fuel pump leaking after shut down...probably the culprit, retightening and we'll see.....what fun we're having this weekend! Good thing PSC has a cockpit sole that lifts off for engine access...
Sapper - it could be that spring on the outlet of the fuel pump is bad. I had to replace mine (entire fuel pump) as the PO had overtightened the outlet it and it never set properly. Removal of the bolt brought out the spring in a badly deformed fashion and I was never able to tighten it (due to the spring). If you have a spare fuel pump and the tightening doesn't work - it may be a good time to swap that out, as you will not be able to rid yourself of that problem ( if that is indeed the case)...
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
